exchange 2010 and 2003 co-existence
  • Thread starter gowtham kakarla
  • Start date
G
gowtham kakarla
Dear Techs ,
I have Exchange 2003 front end and back end topology and windows 2008 GC & DC in my test environment. recently i have installed exchange 2010 in same my environment. All the settings are configured well during exchange 2010 hub and cas server installation. The only thing that needs to be configured is the coexistence information for outlook web app. Because some mailbox's are still in 2003. So client needs to be redirected to Exchange 2003 server.
I am entering the following Management Shell Command to configure outlook web app Co-existence:
Set-OWAVirtualDirectory <CASHUB01>\OWA -ExternalURL https://mail.xxxx.com/OWA -Exchange2003URL https://webmail.xxx.com/exchange
i am getting the following error when i enter the above management Shell command.
The operation couldn't be performed because object 'hostname.domain.com\OWA' couldn't be found on 'ad.domain.com'.
+ CategoryInfo : NotSpecified: (0:Int32) [Set-OwaVirtualDirectory], ManagementObjectNotFoundException
+ FullyQualifiedErrorId : CCD3E873,Microsoft.Exchange.Management.SystemConfigurationTasks.SetOwaVirtualDirectory
please help to solve this problem.
Thanks in advance,
Any Immediate help will Highly appreciated.
Cheers,
gowtham
busbar
try this
get-owavirtualdirectory | Set-OWAVirtualDirectory -ExternalURL https://mail.xxxx.com/OWA -Exchange2003URL https://webmail.xxx.com/exchange
the syntax of the owavirtualdirectoryname is wrong since you need to use identity then the default website name but my cmdlet will ease the pain
Regards, Mahmoud Magdy Watch Arabic Level 300 Videos about Exchange 2010 here: http://vimeo.com/user3271816 Read pretty advanced Exchange stuff I and other MVPs post here: http://www.enowconsulting.com/ese/blog.asp Or follow my blog: http://busbar.blogspot.com or our corp blog: http://ingazat.wordpress.com and if you Liked my post please mark it as helpful and accept it as an asnwer
C
chinni2010
Dear busbar,
Thanks for your immediate reply.....
I entered the above suggested command in management shell. i got the below warning as output..
WARNING: You have changed the InternalURL/ExternalURL for the OWA virtual directory. Please make the same change for
the ECP virtual directory in the same web site.
can i ignore the warning or do i need to change ECP Virtual Directory also?
Cheers,
gowtham
busbar
thanks you welcome.
use this cmdlet:
get-ecpvirtualdirectory | Set-ecpVirtualDirectory -ExternalURL https://mail.xxxx.com/ecp
C
chinni2010
Dear busbar,
i am getting the below error in IE after entering username and password......
Your request couldn't be completed because no server with the correct security settings was found to handle the request. If the problem continues, contact your helpdesk.
cheers,
gowtham.
C
chinni2010
yaa... i restarted both exchange 2003 front end server and exchange 2010 HUB & CAS server....
C
chinni2010
No.... i don't have any SSL Certificate assigned to the exchange 2010 and 2003 server......
busbar
jakebuidoza
hi Mr. Busbar,
Can you please explain what type of internal certificate since there are several ones to choose from. And will I need one for the new cas and one for the legacy server?
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
B Move mailbox from Exchange 2003 to 2010 Exchange Server Administration 2
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
S exchange 2003 org to exchange 2010 org Exchange Server Administration 2
A OWA redirection in exchange 2010 and 2003 Exchange Server Administration 1
H Exchange 2003 to 2010 Transition, Public Folders Exchange Server Administration 2
K exchange 2010 OWA and exchange 2003 coexist Exchange Server Administration 1
A I have purchased a replacement computer and installed Outlook 2010. My server is a 2003 small business exchange server. How can I access the calenda Using Outlook 1
M Exchange 2010 Outlook Web App via Exchange 2003 Front End Server Exchange Server Administration 1
J Exchange server 2003 to 2010 Exchange Server Administration 1
L Exchange 2003 to 2010 Migration - Public Folder Replication Failed - Busy/Free Issue Exchange Server Administration 8
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
D Unable to search contacts in Outlook 2003 - Exchange 2010 Using Outlook 2
J Understanding Exchange 2010 <-> Exchange 2003 Connectors....help... Exchange Server Administration 4
W Outlook 2010 Free/Busy Data not updated\viewable - Exchange 2003 SP2 Using Outlook 2
D Exchange 2003 to Exchange 2010 mail stuck in Exchange 2003 Local Delivery Queue Exchange Server Administration 10
S garbage mail recieved from Exchange 2010 HUB to Exchange 2003 user. Exchange Server Administration 2
I Copying mailboxes from Exchange 2003 to Exchange 2010 Exchange Server Administration 3
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
J Migration Exchange 2003 to 2010: OUT OFFICE ISSUE Exchange Server Administration 8
J Exchange 2010 / 2003 OWA Problem Exchange Server Administration 2
A windows 2003 server with exchange2003 server migrate to windows 2008 std with exchange server 2010 Exchange Server Administration 1
B Exchange 2003 -> 2010 Issues + Public Folder Issues Exchange Server Administration 9
L Exchange 2003 on SBS to migrate Exchange 2010 Exchange Server Administration 2
B Outlook 2010 unable to connect to a remote Microsoft Exchange 2003 server Using Outlook 8
M Exchange 2010 and 2003 Public folder replication Exchange Server Administration 16
C Manage OWA access during the migration from Exchange 2003 to Exchange 2010 (Resource Forest) Exchange Server Administration 4
M Moving mailboxes from Exchange 2003 to 2010 - how to calculate move request batch size? Exchange Server Administration 3
S Replication of Exchange Public Folder from 2003 to 2010 Exchange Server Administration 6
J New Exchange 2010 tot 2003 network Exchange Server Administration 2
L Is that possible to deploy Exchange 2010 into 2003 SBS network? Exchange Server Administration 1
D How to move an exchange mailbox back from 2010 to 2003 Exchange Server Administration 2
G Outlook 2003 displaying x400 instead of E-mail address when viewing Exchange 2010 GAL Exchange Server Administration 6
B Outlook 2003 Free/Busy issues after migrating to Exchange 2010 Exchange Server Administration 5
N Exchange 2010 migration from 2003 Exchange Server Administration 7
E Exchange 2010 in an SBS 2003 environment Exchange Server Administration 2
C Outlook 2003 Calendar Issues in Exchange 2010 Using Outlook 5
J Exchange 2003, 2010 Co-existence. Mail flow problems. Exchange Server Administration 3
B Routing Group Connector between Exchange 2003 and 2010 Exchange Server Administration 2
M Public Folders in Exchange 2003 not available in Exchange 2010 Exchange Server Administration 11
C Synchronization: Exchange 2003 & Exchange 2010 CrossForest Exchange Server Administration 3
