Rule limiation regarding Outlook 2007 on workstation in conjuction with Small bus server 2008 and echange 2007
K
kdepc
Do I understand correctly, if I upgrade from Outlook 2007 to outlook 2010, I would be able to have more rules allowed on my workstation, which is connected to a small business server 2008 using exchange 2007? In other words, how do I expand the rule functionality on XP pro workstation connected to the exchange server so I am not be limited by my outlook 2007 rules? It says that I am out of space. What do I have to click on and which computer do I click on it. Where do I go in exchange 2007 on small business server 2008, within the core store, to expand the public and personal folder rule limitations?
Triton.Deep
In Exchange 2003, each mailbox had 32 KB of storage for outlook rules. In Exchange 2007 and Exchange 2010, the default storage for outlook rules was raised to 64 KB and is configurable up to 256KB. To give yourself more room for your outlook based rules, you would use the set-mailbox command, for example if you wanted to modify everyone on your exchange server, you could try something like this:
get-mailbox | set-mailbox -RulesQuota:256
Or if you wanted to set it for one person only:
set-mailbox aliasname -RulesQuota:256
Here are a few links for further reading:
http://www.slipstick.com/rules/32kb.asp http://technet.microsoft.com/en-us/library/bb123981.aspx http://msmvps.com/blogs/andersonpatricio/archive/2007/07/03/increasing-the-rules-quota-limit-in-exchange-server-2007.aspx http://support.microsoft.com/kb/886616
One last thing to note, disabled rules do not count against your storage quota. Hope that helps.
Jason
L Making rule to move email to folder from one O365 domain Using Outlook 1
Ascar_CT Rule behavior analysis - any tools available? Using Outlook 0
Liza Creating a rule in outlook to filter messages Using Outlook 0
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
B custome rule Outlook VBA and Custom Forms 2
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
M Rule option Using Outlook 2
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Transactional emails - mail rule Using Outlook 3
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
