Out Of Office and Free/Busy no longer work
  • Thread starter Mark DeDionisio
  • Start date
Mark DeDionisio
So, I have been troubleshooting this for a while now. I suspect that it may have stopped working after following instructions in technote to resolve the persistent certificate error that users were getting after installing Outlook 2007. Trying to run the Out Of Office assistant produces the error "Your Out of Office settings cannot be displayed, because the server is currently unavailable." I've seen so many references to this error, but no solution. I tried applying the Hotfix from MS (KB953595) but it didn't help. Here's what I suspect is wrong: The installed certificate is for companyname.com but the local domain name is companyname.NET. When I try to run the autodiscover test from Outlook it seems to be looking for https://mail.companyname.com/autodiscover/autodiscover.xml but should be going to .NET. OK, fine. I saw a solution which said to run a cmdlet to change the internal url for the autodiscover vdir. That seems to make sense, but every time I run the cmdlet I get an error as follows:
[PS] C:\Documents and Settings\administrator>Set-WebServicesVirtualDirectory -Identity servername\EWS(default web site)-internalUrl https://servername/domainname.net/EWS/exchange.asmx
The term 'default' is not recognized as a cmdlet, function, operable program, or script file. Verify the term and try again.
At line:1 char:63
+ Set-WebServicesVirtualDirectory -Identity servername\EWS(default <<<< web site)-internalUrl https://servername.domainname.net/EWS/exchange.asmx
Where should I go from here?
Mark
James-Luo
The cmdlet is wrong, please use the cmdlet below:
Set-WebServicesVirtualDirectory -Identity "Servername\EWS (default web site)" -internalUrl https://FQDNofServer/EWS/exchange.asmx
Check info:
1.      Please describe the exchange topology
2.      So, the issue is for internal users and all internal users, right?
3.      What's the current value of "internalUrl"? Please use the cmdlet below to check
Get-webservicesvirtualdirectory | Fl
4.      Please run the cmdlet below to check if there's error
Test-OutlookWebServices "identity AliasOfProblematicUser
Troubleshooting:
1.      Please try to use OOF via OWA, if there's no issue, we know that issue isn't caused by OOF itself, maybe related on the web service
2.      We can check the authentication of EWS via IIS, verify if "Integrated Windows Authentication" has been checked
3.      Please check if "Enable HTTP Keep-Alives" is checked properly in the IIS [6.0 | 7.0]
4.      Please check the OOF log on the outlook client
a.      Outlook->"Tools" menu->click "Options"->click "Other" tab->click "Advanced Options"
b.      Select Enable logging (troubleshooting), and then click OK
c.       Restart outlook, and try to reproduce the issue, check if any error info exists in the OOF log (like 20081211-121438177-oof.log)
Log location: Start->Run->%temp%->"Olkas" folder
Rhys Watson
I know this is really old but I'm posting here as I've had this problem and all the stuff I found on the web didn't fix it for me but I got there in the end.
My SCP path was correct, all URL's were correct, DNS correct blah blah blah.
Anyway I had the same errors when running the autoconfiguration test on Outlook as most posts on the web and my users couldn't set OOF on Outlook 2007 but could on Outlook 2003 and OWA. That pointed to an autodiscover problem.
My Authentication settings were fine but what I found was when trying to connect to the autodiscover.xml file (https://whateverURL/autodiscover/autodiscover.xml) I was prompted for authentication.
My authentication was set correctly so I check the SSL settings in IIS for the autodiscover virtual directory. SSL was on as it should be but the client certificate settings was set to Accept. Changed this to ignore and suddenly OOF worked and the test email autoconfiguartion in Outlook worked too.
Hope this helps someone.
G
Gerryvs
Hi Folks,
Rhys's post helped me searching in the right direction, we experienced similar problems on one of our CAS servers and it turned out that the access to the autodiscover.xml, struggled a bit with the IP Accesslist on the several subsites and finally was able to open the url in explorer. Tested OOO and all worked fine.
So opening the autodiscover url certainly helps out troubleshooting this and some other issues !
Best Regards,
Gerry Van Steerteghem
Van Steerteghem Gerry
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
L Can signatures synch to Office Portal Using Outlook 1
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
Jennifer Murphy Outlook can't connect to Office 365 at resort hotel Using Outlook.com accounts in Outlook 1
J Outlook Office 365 Win 10 how do I control background colors of events? Using Outlook 1
L Outlook Office 365 client: won't remember my setting File, not to collapse ribbon Using Outlook 2
J Migrate from godaddy 365 to office 365 home Using Outlook 8
Microfiche Migration from Office 2016 H&B to Office 365 Using Outlook 0
R How Can I backup office 365 account? Exchange Server Administration 1
O Office 365 Outlook - mark to download Using Outlook 0
T O365 and Office Message Encryption Exchange Server Administration 2
V Multiple Calendars in Outlook To-Do Bar; Office 365 Using Outlook 3
L Office 365 cloud based rules Using Outlook 1
T Office 2013 no longer updating automatically Using Outlook 2
O Office 365 - Outlook - Password protect your mailbox Using Outlook 7
Horsepower Office Outlook 365 home opens slower than a month ago Using Outlook 8
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
O Backup Office settings - registry key Using Outlook 5
L Need to import multiple Outlook files to Office 365 Account Using Outlook 4
J Out of Office, Delegate Using Outlook 1
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
B Search function in Office 365 has stopped working Using Outlook 3
L Outlook Office 365 cached mode crashing Using Outlook 0
P Oulook addin unloaded in office 2007 Outlook VBA and Custom Forms 2
Fozzie Bear Office 365 Home Premium with Exchange Online email accounts Using Outlook 3
mrje1 Outlook 2016 Manual Email Account Setup, what is the Office 365 option etc., and Crashes Using Outlook 0
I Import Office theme .thmx Using Outlook 4
