Exchange 2007 Linked Mailboxes and Shared Calendars
Jon-Alfred Smith
Is it possible to make this work? Let's say we have two domains, the resource domain (RES) and the account domain (ACC).
We have these two users: she and he. She and he authenticates in ACC with ACC\she and ACC\he. Both have disabled user accounts in RES: RES\she and RES\he with mailboxes.
Now ACC\he offers to share his Outlook Calendar to She. What happens is, the mailbox is shared to RES\she, not ACC\she. This can easily been seen with PFDAVAdmin (he / Top of Information Store / Calendar /Permissions). The result is: She cannot access He's calendar
Two-way forest trust is in place. I have tried adding She to a domain local group and add that group to the Calendar. Does not work, that is adding does not work.
Has anybody made this work? Any suggestions? Thanks in advance!MCTS: Messaging | MCSE: S+M | Small Business Specialist
Jon-Alfred Smith
The two domains are of course within two distinct forests.
James-Luo
Does the calendar sharing ever work before among the linked mailboxes?
Please see if the issue can be reproduced by using two newly created test mailboxes
The first part of this is making sure the following criteria are met for shared calendar:
1. There is an Enabled account in the user account forest (ACC) (Checked)
2. There is a Disabled account in the resource forest (RES) (Checked)
3. The two forests trust each other (Checked)
4. The Enabled account has been added as Associated External Account with “Full Mailbox” access permission on Disabled account
Notes: There"ll be an attribute named “msExchMasterAccountSid” created on disable RES account, the value of the property is set as the SID of the account in ACC forest
5. The delegate (She) mailbox and mailbox owner (He) mailbox reside on the same server
When we added the permission on shared calendar, the RES/she"s “msExchMasterAccountSid” attribute will be added. When ACC/she tries to access the shared calendar, ACC/she submits her SID and the shared calendar will find the “msExchMasterAccountSid” attribute. It will allow her to access the data. So please check the attribute on the AD user object of RES/he
Does the RES/he an enabled mailbox before? Please try the procedure below:
1. Enable RES/he
2. Remove RES/he from the shared calendar permission list
3. Disable RES/he again
Notes: I would suggest to restart “Information Store” service to make sure store can detect this account is disabled. If it is not possible, please wait at least 2 hours
4. Add RES/he back to the permission list
5. Then, see if the issue is still reproducible
James Luo
Jon-Alfred Smith
Thank you so much for your answer, and awfully sorry for not having kept this thread updated. I'll know more later this evening.
Jon-Alfred Smith
Now it works! Thanks again for your detailed answer.
Suriya25
Hi James,
Hope you can guide on this same issue. I have a problem with mailbox user unable to give shared his calendar to linked mailbox user. I'm follow your above instruction but still failed for linked mailbox user to access shared calendar. The error message when link mailbox try to open the shared calendar is " You do not permission to view the calendar, would you like to ask permsiion from mailbox user" . I click yes then mailbox user will received email from link mailbox asking for permission. I click Yes but the permission which allow is only READ. I would like to have link mailbox user to have EDITOR on shared mailbox.
Please advice.
norbertlars Exchange 2007 - quota not shown in clients Exchange Server Administration 2
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
Diane Poremsky Outlook 2016 & Exchange 2007: Not supported New Slipstick.com Articles 0
D Multiple Exchange Accounts in 2007 Using Outlook.com accounts in Outlook 1
B Old attachments do not open after Exchange 2007 edb recovery. Exchange Server Administration 3
TotallyConfused Godaddy Microsoft exchange 2007 stopped updating Exchange Server Administration 1
W Sync categories between Exchange and 2007 Exchange Server Administration 1
J Outlook 2013 - Exchange 2007 manage distribution group Exchange Server Administration 1
Jon Bakrley Outlook 2013 and Exchange 2007, Out of the office error message Using Outlook 8
W Moving Exchange 2007 to a different drive/partition? Exchange Server Administration 1
M connection to the microsoft exchange server has been lost. outlook 2007 Exchange Server Administration 0
R Ingest contact PST from exchange 2007 thru client's Outlook via PRF Exchange Server Administration 2
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
S Installing Exchange 2007 on Outlook 2007 with a previous POP3 account Using Outlook 1
B Promoting and demoting dns w/ exchange 2007 sp2 environment Exchange Server Administration 1
S Outllook 2007 stops connecting with Exchange after latest MS Updates Using Outlook 2
D Removing multiple Exchange 2007 servers on the same Domain and site Exchange Server Administration 1
A Identifiying who changed or updated an appointment in Exchange 2007 Exchange Server Administration 7
S Outlook 2007 Rules randomly stopping working (non-Exchange Server) Using Outlook 6
T Multiple Mailboxes not Synchronizing with Exchange 2007 Exchange Server Administration 0
M Outlook 2007 "cannot open your default email folders.microsoft exchange is not available" on XP is n Using Outlook 1
M Outlook Anywhere not working for Exchange Server 2007 Using Outlook 7
X Exchange 2007 Outlook Anywhere Clients unable to retrieve GAL Using Outlook 9
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
C Exchange 2007 Shell command to find users who are members of Recipient Administrator Exchange Server Administration 3
M Outlook 2010-Sync with Exchange server 2007 Using Outlook 2
J outlook 2011 for mac not connecting to exchange 2007, previous entourage does & i can ping the serve Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
M Outlook 2010 Connectivity with Exchange 2007 Using Outlook 5
M Outlook 2010 Connectivity with exchange server 2007 Using Outlook 1
A cannot connect outlook 2007 clients to exchange 2010 Exchange Server Administration 3
D How to push a second outlook 2007 'private' calendar on exchange 2007 to my mobile phone. Using Outlook 1
V Daylight savings times X Exchange 2007 pop3 Using Outlook 2
M Appointments with more than one day are not shown correctly at iPhone after Service Pack 3 for Exchange 2007 Using Outlook 2
S Can not find a mailbox - Exchange 2007 Exchange Server Administration 1
M Outlook Mail Format Options - Grayed out 2003 office/outlook in exchange 2007 mail organisation. Using Outlook 3
R Unable to use Public Folders on Exchange 2007 via OLK2007 Using Outlook 2
P Problems with shared Calendars in an Exchange 2007 and Outlook 2007 environment Using Outlook 1
M Is it possible to have a public calendar map on a exchange server 2007 and synchronize this map and the items with outlook 2011 for MAC public map bro Using Outlook 2
K Exchange 2007 user can't receive mails without going offline and then online again Using Outlook 8
J Oulook 2007 Vs. Exchange 2010...always asked about login validation... Exchange Server Administration 9
A Exchange 2007 <-> 2010 OWA not working together redirecting problem Exchange Server Administration 1
G Share calendar between two Outlook 2010 OR 2007 without exchange where both users can make appointme Using Outlook 1
