Outlook 2007 keeps prompting for password after update, please help!
jrdtech
We just updated our SBS 2008 with exchange 2007 setup and right after the updates all users started receiving a dialog box when opening their outlook client. The strange thing is the dialog box has the external FQDN on top remote.mydomain.com the username is formated \\servername\user when I enter the users password it just comes right back up like the password was rejected. If I cancel out it says 'Need Password' in the lower right corner of Outlook. Now the users can still send and receive mail but everytime the send and receive is initiated the box comes up. I know your probably going to need some sort of log, unfortunately I don't have access to the server right now but I'll be there tomorrow. In the mean time so I don't waste another day figuring this out can someone post any solutions for this type of issue that I can try? I'm a newbie with exchange so please be gentle! Thanks.
Mike Shen
As the user is still able to send/receive email, I believe Outlook can still connect to Exchange mailbox server. I suspect that the issue occurs because incoorect Autodiscover settings. Which Outlook client is used? Outlook 2007 or Outlook 2003?
If it is Outlook 2007, please check whether the Autodiscover URL or other Web Services URL is configured correctly? You can run Test-OutlookWebServices command to check whether any external URLs are configured?
By the way, how Outlook 2007 connects to Exchange Server? TCP or RPC over HTTP?
Mike
Allen Song
Whether all users had this issue or just certain user? Could you download the OAB? Please press Ctrl+right click the Outlook icon in System Tray, then select Test E-mail AutoConfiguration, click Test button, then post the information under Logs Tab.
Allen
SteveMACK
I have also experienced this problem after restarting our SBS 2008 server, after which updates were installed. I initially posted this on the Outlook forum but i was advised to re-post in this forum.
In my situation, this problem only occurs on Windows 7 machines running Outlook 2007 clients on our LAN network. Machines running XP with Outlook 2007 / 2003 do not exhibit this behaviour. Also if a Windows 7 machine that does show this behaviour on the network, connects via our VPN it is not asked for a user password to log on to exchange.
I am also waiting for an answer to this problem.
Regards
SteveMack
E
EEzyIT4U
Hi Andy
We are running SBS 2008 SP2 and am experienceing the EXACT same prompt / problems as SteveMACK do you have any feedback yet ?
I ran the auto connect wizard, UNABLE to auto connect ..... How do I export the LOG so I can post it where you wanted it ?
Awaiting response Mike
Rhindle
%windir%\System32\inetsrv\appcmd.exe set config -section:windowsAuthentication /useKernelMode:false
Fixed my problem on SBS 2008. :D
Thanks!!
E
EEzyIT4U
Here is the answer to this problem. On the server do the following: Click Start >>> Run >>> CMD " Hold Left SHIFT in " Click OK. Now type the following COMMAND in: " %windir%\System32\inetsrv\appcmd.exe set config -section:windowsAuthentication /useKernelMode:false" now Enter. exit and VOIALA it goes away.Mike Prinsloo [CLP][CNE]
btastet
this did work for me - However, it broke my ability to login to remote web workplace - I could login to the front page, but I could not access remote machines or owa - is there another option? thx in advance! Bill
J Secondary Outlook 2007 Mailbox keeps disappearing from Users Outlook Folder List dispite her being d Using Outlook 2
C Outlook XP keeps dropping connection to Exchange 2007 Using Outlook 3
J Cert warning for outlook 2010 keeps popping up in Exchange 2007 environment Using Outlook 1
B outlook 2007 password prompt keeps popping up Using Outlook 1
E My Outlook 2007 keeps crashing (actually refuses to open completely) and giving me this error messag Using Outlook 3
I Outlook 2007 keeps shutting down Using Outlook 3
H Outlook 2007 keeps prompting for login credentials Using Outlook 3
D Outlook 2007 new installation keeps downloading duplicates of mail messages already downloaded. Using Outlook 1
P Outlook 2007 Keeps Closing Using Outlook 1
R Not able to configure Outlook 2007 back to Yahoo after microsoft update crased the computer.__After restart lost email service.__Email keeps asking fo Using Outlook 2
R Outlook 2007 Favourites folder keeps disappearing Using Outlook 2
T sending multpule large emails __i have micrsoft office outlook 2007 and a new computor, when sending emails larger than 2 MB outlook just keeps on re Using Outlook 0
J Outlook 2007 keeps going into offline mode. Using Outlook 6
S Enter Network Password Box keeps popping up in Outlook 2007 Using Outlook 3
F My Vista outlook 2007 keeps restarting about every 5 minutes!!! Using Outlook 0
T Outlook 2007 keeps downloading the same emails over and over. Using Outlook 1
C outlook 2007 keeps hanging on not responding Using Outlook 1
S Outlook 2007 keeps closing and restarting....help Using Outlook 2
T Outlook 2007 keeps prompting users for password Exchange Server Administration 3
E outlook 2007 startup wizard keeps opening Using Outlook 2
E Outlook 2007 (OWA) Keeps asking for Password!!! Using Outlook 6
T Outlook 2007 keeps prompting for credentials Using Outlook 17
M PST import from Outlook 2007 to 2010 - Address Book contacts all in 1 group Using Outlook 3
