OWA2010 How to search for appointments?
RonHou123
In OWA2003 you could search for appointments.
When you clicked on the root of the mailbox, and you started the search there, it would find appointments.
But in Outlook Web App of Exchange Server 2010 it only finds emails.
Does anybody know how you can search for appointments?
Kind regards,
Ron
Richard Wang
Please select entire mailbox in OWA.Your expertise never fails to impress!
S OWA2010 Problem after installation of Exchange 2010 SP1 Rollup1 Using Outlook 4
D Disable conversation view by default? (OWA2010) Exchange Server Administration 1
L New Location for the Search Bar Using Outlook 5
King Mustard Sort search groups by amount of items? Using Outlook 1
T Search for incoming e-mails for a specified time range Using Outlook 1
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
W Search Incomplete Outlook 2016 Using Outlook 5
R outlook address book search broken Using Outlook 2
R What's supposed to appear when just clicking into the search field? Using Outlook 7
B Instant search with special characters Using Outlook 1
A Search folder refresh Outlook VBA and Custom Forms 3
M email search not working Using Outlook 1
F Search folder for tasks in all task folders Using Outlook 1
B Search: Cannot find which Folder Contains a Message Using Outlook 3
M how to speed up search of shared contacts Using Outlook 0
C Search with Google Macro? Outlook VBA and Custom Forms 4
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
E Outlook 2016 Inbox search bug Using Outlook 1
P Outlook search is not working at all for Calendar & Tasks Using Outlook 7
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
M new search just... sucks Using Outlook 4
B Search function in Office 365 has stopped working Using Outlook 3
J Marco in search of text in subject line Using Outlook 8
T Delete Emails from search results Outlook VBA and Custom Forms 1
P Can't search Archive'd Tasks Using Outlook 0
