outlook 2010 takes more than 5 minutes to open another user's calendar
Sul
I am connecting to an exchange 2007 server with outlook 2010 client. when i try to open another user's calendar i have to wait at least 5 minutes before the calendar events get populated on the screen. I did not have this problem in outlook 2007 nor outlook 2003.
any suggestions?
thanks!
-sul.
Richard Wang
Would you please let me know the version of your exchange 2007 and the operation system of your client?
I will make a lab test for this.
Because my lab environment are exchange 2007 SP2 and office 2010 in vista.
Your expertise never fails to impress!
Sul
Hi, this is my current environment:
client: outlook 2010 on windows 2007 32bit. exchange server 8.3 build 83.6 (Service Pack 3).
-s.
Richard Wang
Hi Sul
I'm sorry for the late reply.
I have make a lab as the same environment as you. User in Outlook 2010 could open other's calendar immediately.
When I send a sharing calendar invitation to user A. User A could open this calendar in the invitation mail without problem.
T Outlook 2010 takes much longer than expected to download an e-mail message from a POP3 server Using Outlook 1
S outlook 2010: takes more than 5 minutes to open other user's calendar Using Outlook 1
S outlook 2010: opening other user's calendar takes a long time to display Using Outlook 5
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
M PST import from Outlook 2007 to 2010 - Address Book contacts all in 1 group Using Outlook 3
V Hotmail account on Outlook 2010 Using Outlook 2
