Custom RBAC question
C
Chad Solarz [MVP]
I have a student who took my 10135 class and asked a great question on custom RBAC permissions. I understand RBAC and how it works, but i don't know fully the built-in limitations on some of the out of box groups and assignments. They can't easily change their admin structure so that apparently is not an option for supporting RBAC. Please see below..
Here is what they have.
OU structure
Root
Companies (Static name)
Country (Name of the country the company is located in)
City (Name of the city the company is located in)
Company (Actual Company name or abbreviation of it)
Computers
Contacts
Groups
Servers
Users
Within thrir current configuration they have the security broken down into 5 types of administrators listed below.
1. Account
a. Can create Users and manage Users in Users OU
b. Can create and manage Groups in Groups OU
c. Can create and Manage Contacts in Contacts OU
2. ServerAdmins
a. Can create and manage computer objects in Servers OU
b. Add via VBscript and GPO to local administrators group of the machine.
3. SystemAdmins
a. Can create and manage computer objects in Computers OU
4. GPOAdmins – Being phased out
5. ExchAdmins – Being phased out
Because they have the administration split up so much there is multiple levels of each of these groups. They have CityCompany, City, Country, Company, Division and Region group.
So for one location they would have
Standard local Administrator
NapervilleFarmTechnologiesAccountAdmins
NapervilleFarmTechnologiesServerAdmins
NapervilleFarmTechnologiesSystemAdmins
NapervilleFarmTechnologiesGPOAdmins
NapervilleFarmTechnologiesExchAdmins
Give admin rights to any company within the city
NapervilleAccountAdmins
NapervilleServerAdmins
NapervilleSystemAdmins
NapervilleGPOAdmins
NapervilleExchAdmins
Give admin rights to any company within the country
USAAccountAdmins
USAServerAdmins
USASystemAdmins
USAGPOAdmins
USAExchAdmins
Give admin rights to any FarmTechnologies (Company name)
Grant permission to any company within the division (5 divisions possible)
FT-AccountAdmins
FT-ServerAdmins
FT-SystemAdmins
FT-GPOAdmins
FT-ExchAdmins
What they were originally planning was using the RecipientOrganizationalUnitScope option within the managementroleassignment the problem that they ran into this is that it appears to only allow one root OU within the scope and they would need several when it comes to some of the country admins. they have considered using the managementscope option as well and filter by some of the attributes but of course MS decided that some of the attributes that we need like division is not available. If they used this on a city level they would not be able to lock the admin into putting the groups in the groups OU but instead they could put them anywhere.
Now for the question that you have all the background material. Are we mistaken or does the OU scope allow multiple root OU to be defined? Do you know of another way to accomplish the security that they need?
Chad Solarz Sr. Tech Instructor Directions Training MCSA / MCSE / MCDST / MCT MCTS: Vista / exch 2k7 & 2010 / server 2k8 / forefront / MDOP / Win 7 MCITP: Vista / server 2k8 / Exchange 2k7 & 2010 Twitter - @csolarz FB - Http://www.facebook.com/csolarz linkedin - http://www.linkedin.com/in/chadsolarz
Michel de Rooij
Using the ManagementScope cmdlets you can set 1 root per scope using the RecipientRoot parameter. Scopes are attached to ManagementRoles (ManagementRoleAssignment cmdlets) using the Scope parameters on a 1:1 basis. ManagementRoles can be grouped into RoleGroups an are having a 1:N relationship. So - if I read your question correctly - you need to create multiple ManagementRoles for each scope (root).
Regarding the filtering, as you probably found out you can only use a selected number of attributes to filter on:
http://technet.microsoft.com/en-us/library/bb738155%28EXCHG.80%29.aspx
Isn't it an option to use (filter on) groups, phone (prefixes), postal code. Another option perhaps is to sync the required attribute into on of the ExtensionAttribute values and filter on that.
RBAC info and shameless self-plug:
http://eightwone.wordpress.com/2009/12/08/exchange-2010-delegation-model/
Regards,
Michel
Michel de Rooij,
MCITP Ent.Msg 2007+2010| MCTS W2008, Ex2007+2010 Conf | MCSE+Msg2k3 | MCSE+Inet2k3 | Prince2 Fnd | ITIL
I blog on http://eightwone.wordpress.com/ and tweet on http://twitter.com/mderooij
F
Frank.Wang
Hi Chad,
"they have considered using the managementscope option as well and filter by some of the attributes but of course MS decided that some of the attributes that we need like division is not available. "
How about Custom Attibutes which is also can be filtered?
Frank Wang
E Custom formula for columns Using Outlook 3
witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
O Searching for Custom Flags Using Outlook 3
P Outlook custom fields "events" Using Outlook 0
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
S Custom form with dropdown Using Outlook 0
