why does Outlook 2010 crash whenever I double click an email __
mikie1046
Remember - This is a public forum so never post private information such as email or phone numbers!
Ideas:
Programs you are having problems with Error messages Recent changes you made to your computer What you have already tried to fix the problem
Sachin Shetty
Does Outlook crash when you double-click on any email or a particular one?
Which operating system do you use?
What type of email account do you use in Outlook?
Do you face the same issue with contacts and appointments stored in Outlook?
Try the following steps:
1. Click on Start > All Programs > Accessories > Run
2. Type outlook /safe
Note: add a space between outlook and "/"
3. Verify the status in Outlook safe
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
O Outlook 2010 does not open MS Word attachments Using Outlook 1
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
F Outlook 2010 contact e-mail Display as: does not show contact name Using Outlook 2
P Reply All does not work in Outlook 2010 Cached mode Using Outlook 4
E Does Outlook 2010 support searching multiple .pst files simultaneously? Using Outlook 0
D Outlook 2010 randomly does not receive emails Using Outlook 3
D Does anyone understand Outlook 2010??? Using Outlook 1
C Outlook 2010 - Your network adapter does not have a default gateway. Using Outlook 1
S Outlook 2010 Journal does not record activities on Office 2007 files Using Outlook 1
J Suggested times does not work with Outlook 2010 in combination with Exchange 2007 SP2? Using Outlook 2
T Outlook 2010 does not save "sent" messages Using Outlook 1
B outlook 2010 Search does not show recent messages Using Outlook 4
C Outlook 2010 does not Clean Messages from Server Using Outlook 1
M iPad does not Sync with Microsoft Outlook 2010 Contacts, Calendar, Etc. Using Outlook 2
T Outlook Today does not display in Oultook 2010 Using Outlook 3
R Outlook 2010 does (partial) not save to NormalEmail.dotm? Using Outlook 1
W How does Folder Synchonization Work in Outlook 2010 Using Outlook 1
B In Contact Properties of Outlook 2010, it does not allow me to check the check box " Show this folde Using Outlook 2
B Re: In Contact Properties of Outlook 2010, it does not allow me to check the check box " Show this f Using Outlook 2
A Outlook 2010: Conversation view does not show messages that are in a folder. Using Outlook 4
C Live Messenger does not send email messages to Outlook 2010 Using Outlook 3
J __This is on outlook 2010...I can receive but does not send out.__ Using Outlook 2
J OUTLOOK 2010 Does not check E-mail when off-line Using Outlook 7
C Managed Folder does not show up in Outlook in Exchange 2010 Sp1 Rollup 1 Exchange Server Administration 3
M In Outlook 2010, upon deleting an open e-mail, the next e-mail does not open automatically in full s Using Outlook 2
O Outlook 2010 does not store password Using Outlook 1
G Where does Microsoft Outlook 2010 save my information and configurations? Using Outlook 1
P My Outlook 2010 won't delete files, or at least, sometimes it does, sometimes it doesn't.__ Using Outlook 1
M Upgrading from Excahnge 2003 to Exchange 2010 how does it effect outlook client users Exchange Server Administration 7
B Outlook 2010 does not connect to email servers. Using Outlook 2
C Where does the sent mail in outlook 2010 go to? Using Outlook 1
C windows contacts search in MS Outlook 2010 does not work Using Outlook 1
T outlook 2010 deleting email dissapears and does not appear in deleted files folder Using Outlook 4
T Outlook 2010 does NOT start. Using Outlook 2
M Outlook 2003/2007/2010 not showing attachments but OWA does Using Outlook 6
M Does a shared Outlook BCM 2007 database work with both Outlook BCM 2007 and 2010 clients? Using Outlook 2
L Magnifying glass does not move when searching messages in Outlook 2010 and another related question Using Outlook 3
J Outlook 2010 does not show some messages after upgrade from Office 2003 to 2010 Using Outlook 1
P Outlook 2010 smtp.live.com gives error that server does not support encryption. Using Outlook 2
K Outlook 2010 spellcheck and synonym does not work with word 2007 Using Outlook 1
B Search Does Not Work in Outlook 2010 Using Outlook 2
T Pressing the signature or stationery buttons in outlook 2010 does nothing. Using Outlook 1
B forward button in Outlook 2010 toolbar is greyed out and does not work Using Outlook 2
D All Accounts Send/Receive Group does not download complete item after upgrading to Outlook 2010 Using Outlook 2
A outlook 2010 does not show category view Using Outlook 8
P Outlook 2010: POP3 Gmail does not send mail. Using Outlook 2
