Customize Colours
amdm55
Need to change colours on the colour pallete within Outlook 2010 for the Alphabet letters.
There are colours already on the pallete BUT they are not bright colours. The brighter colours are on another pallete behind the main pallete - but although we cna get the colours we want they are ONLY Temporary.
I need to replace some colours of my own choice form the hidden pallete onto the main pallete.
How can I change these colours on the main pallete ?
Shane Devenshire
You can create a custom Theme - start with a new blank message and choose Options, open the Colors menu and choose Create New Theme Colors...
After you finish open the Themes menu and choose Save Current Theme.
To change the overall look of your Microsoft Office Outlook 2010 document, you change both the theme and the style set. You can then set this as the default for all new e-mail messages.
Click the File menu, and then click Options.On the Mail tab,click Stationery and Fonts.Click Theme. Select the theme that you want, and then click OK. Click OK. If this answer solves your problem, please check, Mark as Answered. If this answer helps, please click the Vote as Helpful button. Cheers Shane Devenshire
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT New Slipstick.com Articles 0
M Customize CreateItemFromTemplate Macro Outlook VBA and Custom Forms 2
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
M please customize this code Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
P How may I customize with an own immage a standard email Using Outlook 6
D In Outlook 2007 on Windows 7 64 bit Customize Current View 'Other Settings' Fonts changes do not hold Using Outlook 2
K Can I customize OL2010 month view calendar to be more legible; skip confusing colors and show more a Using Outlook 1
W Customize accounts (folderlist) in navigation pane Using Outlook 5
J Customize Outlook view to fit Smartphone display via i.e. Citrix Receiver ? Using Outlook 1
M Customize Current View of PST Files Using Outlook 2
P Customize Appointment Form Using Outlook 1
U How to customize exch 2010 smtp bounced msg like 5.7.1 or 5.7.11 Exchange Server Administration 2
S Customize Text on OWA Change Password Form Exchange Server Administration 3
J How to customize the To-Do list to show items from only one specific mailbox? Using Outlook 2
J The filter Button is dimmed in the View - Customize Current View dialog. Using Outlook 2007 on Exchange. Using Outlook 3
C Customize Themes Exchange 2010 SP1 Exchange Server Administration 4
R customize contacts Using Outlook 1
K OWA 2010 - Any way to customize the Calendar Sharing Invitation? Exchange Server Administration 1
G BCM 2007 Customize Current View not sticking Using Outlook 2
C Customize Current View - Group By & Remove This Column Using Outlook 2
A when i customize new fields in the contact menu, it displays under define fields but does not display when trying to imput a new contact. Using Outlook 1
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
R Any idea why my category colours aren't showing in my calendar? Using Outlook 0
Z bulk add categories / with fixed colours / select multiple categories on a not Using Outlook 1
J Outlook 2007 - Shared Calendar Category Colours Using Outlook 1
