Reminders order
poz3614
The reminders have always seemed backwards to me. e.g. closest reminder is on the bottom of the list. I would perfer that the closest appt by calendar date be on the top of the list. Is there anyway to do that?
They should be newest on top - they are here. Try closing outlook and restarting with the cleanreminders switch.
Close Outlook. At the Start search field on Vista or Windows7 Start menu or in the Start menu, Run command (Windows key + R), type
outlook.exe /cleanreminders
Then press Enter (or OK button) to restart Outlook.
Note: Make sure there is a space between the words.
