Exchange 2010 error when preparing schema
bogie13
I am installing Exchange 2010 in a Windows 2003 SP2 domain running in native mode. We are upgrading from Exchange 2003. The two will not need to coexist. On a new 2008R2 x64 box, I've run setup /pl. Here is what happens when I then run setup /p:
Organization Preparation ......................... FAILED
The following error was generated when "$error.Clear(); if($RoleUpdateResourcePropertySchema) { set-resourceconfig
-ResourcePropertySchema $null -DomainController $RoleDomainController }" was run: "Couldn't perform the operation becaus
e objects of type 'Microsoft.Exchange.Data.Directory.SystemConfiguration.ResourceBookingConfig' couldn't be found on 'DC.mydomain.corp'
I have seen this issue addressed for Exchange 2007 installs here: http://support.microsoft.com/kb/949526/en-us
I imagine the solution is similar, perhaps as simple as following the referenced solution, but with a different msExchVersion attribute?
Please let me know if I can provide any other helpful information.
MTNG
Please try run setup /prepareschema at first, and monitor the result. If the result still appear the same, you should try the solution guided by Microsoft.
http://technet.microsoft.com/en-us/library/bb125224.aspx
That is the closest similiar solution to this problem, and it related to missing resource schema object in AD .
(Not exchange version).
This problem occurs because the Resource Schema object under Global Settings in Active Directory directory service is missing.
My suggestion is you should try create the Resource Schema object and run again the exchange prep.
MT
bogie13
Frank,
Thanks for the reply. I tried following the procedure for the same issue with Exchange 2007 described in http://support.microsoft.com/kb/949526/en-us to the letter, and it solved the problem. I was then able to prepare the schema, and then prepare AD without any further issues.
MTNG, The link you provided didn't provide any resolution to the problem, but your suggestion that I create the Resource schema object was indeed the answer.
JB
MTNG
Thanks for update, at least we get shared what's how to repair it next time.
Cheers, your problem resolved :)
MT | MCITP ----- Please vote helpful or mark as answer if it's answered your question, this help us follow up the question status.
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
M Exchange Server 2010 Installation error ""The domain is invalid. Property Name: Domain" Exchange Server Administration 4
J exchange 2010 error log Exchange Server Administration 0
S New Outlook 2003 Clients with Existing Exchange 2010 error's Exchange Server Administration 6
S Exchange server 2010 installation error Exchange Server Administration 3
D Exchange 2010 SP1 OWA "reply" or "forward" error Exchange Server Administration 3
J Exchange 2010 SP1 fails at Mailbox Error Unable to load exrpc32.dll Exchange Server Administration 4
I Error when install Service pack 1 on Exchange 2010 Exchange Server Administration 5
D Exchange 2010 SP1 topology prep error Exchange Server Administration 3
D Outlook 2003 is getting an error when trying to open an exchange 2010 mailbox Exchange Server Administration 5
S Exchange 2010 SP1 OWA Error Exchange Server Administration 2
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
P Error 4999 after Exchange 2010 SP1 - No BES server Exchange Server Administration 12
J CANNOT get rid of Exchange 2010 error "An IIS directory entry couldn't be created. The error message Exchange Server Administration 2
D Exchange 2010 Load Generator Error Exchange Server Administration 0
A Hub Trasport error !!!! while exchange 2010 setup Exchange Server Administration 5
S exchange 2010 DPM 2010 (inconsistent state error) Exchange Server Administration 8
B 500 error after authenticating in OWA - Exchange 2010 Using Outlook 1
M WBADMIN Scheduled Backup for Exchange 2010 Fails with Event ID 544 Error Exchange Server Administration 5
S Exchange 2010 ACE Error Exchange Server Administration 3
M Exchange 2010 log error: MSExchangeMailboxAssistants 14029 FreeBusy Assistant Using Outlook 1
L Exchange 2010 SP1 Pre-Req error Exchange Server Administration 2
S Exchange 2010 OWA error 404 with IE 8 Exchange Server Administration 1
S Exchange 2010 SearchIndex-Error after database move Exchange Server Administration 6
C Now the problem I see is that I get an error when installing the Exchange 2010 SP 1. I attach a scre Exchange Server Administration 10
A Sync error in exchange 2010 mailbox Exchange Server Administration 4
K Error Contacting RPC/HTTP Service error in Exchange Server 2010 Using Outlook 8
J How to uninstall Exchange 2003 in Exchange 2010 co-exist environment - Error: Recipient Update Servi Exchange Server Administration 4
M Exchange 2010 SP1 installation error Exchange Server Administration 5
C Active Directory error applying Exchange 2010 SP1 Exchange Server Administration 4
A Error setting up new Exchange Server 2010 on Win2008R2Domain Controller - Couldn't find the Enterpri Exchange Server Administration 4
A Error Installing Exchange 2010 SP1 on Exchange 2010 Exchange Server Administration 5
R Send as permission error Exchange 2010 Exchange Server Administration 9
K Error moving mailbox back to Exchange 2003 from Exchange 2010. Exchange Server Administration 5
M Cant get Exchange 2010 Update Roll up 4 to install. Error: the upgrade patch cannot be installed by Exchange Server Administration 8
Y Task reported error 0x80040105f - Outlook 2010 Multple Exchange Accounts Using Outlook 8
D Outlook 2007 with Exchange 2010 sync error Exchange Server Administration 3
D Mobile Acess to MS Exchange 2010 - "connection to the server failed" error Using Outlook 2
R New meeting request error in Outlook 2010 on a exchange server Using Outlook 3
B 2010 Setup Error - "One or more servers running Exchange 2000" Exchange Server Administration 5
S Exchange 2010 to SP1 Upgrade: Reboot error Exchange Server Administration 1
M Exchange server 2010 installation failed with hub transport server role error Exchange Server Administration 5
O New Exchange 2010 setup with two domains and Error in setup Exchange Server Administration 3
C Exchange 2010 VSS error while taking Backup through Symantec exec 2010 Exchange Server Administration 6
A Exchange 2010 sp1. When i dismount a mailbox database occur error in event viewer Exchange Server Administration 5
A Exchange 2010 sp1. Error opening a bookmark in the EMC Exchange Server Administration 2
W Error Message Office 2010 'the connection to microsoft exchange is unavailable. Outlook must be online or connected to complete this action' Exchange Server Administration 1
M Exchange server 2010 initialization error Exchange Server Administration 5
