Can a DAG Cross Site Bounderies
S Michael Momjian
I am considering adding members to a DAG from two different sites to achieve site resilience. Is this possible?
Background: We have 6 sites two of which are house mailbox servers, hub servers, and client access servers. The choices are as follows:
1) One DAG with 6 servers spanning over two sites.
2) Two DAGs with 3 servers in each site.
Option 1 is preferred as long as DAGs can cross site boundaries. Is Option 1 possible for site resilience?
Infrastructure Architect
Triton.Deep
Yes.
In addition to providing high availability within a datacenter, a DAG can also be extended to one or more other datacenters in a configuration that provides site resilience for one or multiple datacenters. In the preceding example figures, the DAG is located in a single datacenter and single Active Directory site. Incremental deployment can be used to extend this DAG to a second datacenter (and a second Active Directory site) by deploying a Mailbox server and the necessary supporting resources (namely, one or more Active Directory servers, and one or more Hub Transport and Client Access servers), and then adding the Mailbox server to the DAG, as illustrated below.
http://technet.microsoft.com/en-us/library/dd979799.aspx
Jason
If it was helpful, vote for it. If it answered your question, mark it as answered. Small thing to do for free help from a strong community :)
S single DAG two AD sites cross site database failure Exchange Server Administration 3
K Cross site DAG and CAS Exchange Server Administration 7
M cross forest DAG for mailbox database replication Exchange Server Administration 3
S DAG question Exchange Server Administration 0
B Two server DAG setup, second server EMC not opening Exchange Server Administration 3
L DAG Requirements Exchange Server Administration 5
G Mount recovery database fails on DAG Exchange Server Administration 3
S Mailbox Stores not mount in Two Member DAG Exchange Server Administration 4
P DAG CONFIGURED Need to change the data base and log file location .What are the risk .And Steps to p Exchange Server Administration 3
A Exchange DAG Exchange Server Administration 1
V mapiexceptioncallfailed: unable to mount database when activate mailboxdatabase in dag Exchange Server Administration 4
S DAG Content Index failed Exchange Server Administration 2
E Outlook 2007 won't connect to 2nd Mailbox Server in a DAG Exchange Server Administration 2
S DAG with Single Network Card Exchange Server Administration 8
T Exchange 2010 DAG Failover Issue - Database Activation Fails because Content Index Catalog Failed Exchange Server Administration 2
L DAG Question - Help Exchange Server Administration 2
A Access a DAG over a virtual lan ip for backup Exchange Server Administration 1
J Question of Exchange 2010 DAG Exchange Server Administration 3
M Hyper-v vSwitches and DAG Networks Exchange Server Administration 7
A Need Help Urgent !!!- Add Seconde Node To The DAG Exchange Server Administration 12
P 2 Member DAG - Members Virtualised running on non Clustered Hosts - supported Configuration? Exchange Server Administration 2
P Two Member DAG - Reboot Witness Server - Effects? Exchange Server Administration 7
K Exchange 2010 DAG Exchange Server Administration 2
S DAG replicaiton and server maintenance Exchange Server Administration 6
J When a database move from active host in a DAG, user are prompted for credentials Exchange Server Administration 8
à Loss the file share witness of DAG Exchange Server Administration 4
S DAG RPCclientAccessServer Exchange Server Administration 5
K msexchangerepl utilizing high CPU in a DAG env Exchange Server Administration 10
S Extend Exchange 2010 DAG accross sites Exchange Server Administration 3
M DAG layout and space question Exchange Server Administration 2
S DAG manually dismount database Exchange Server Administration 4
M Exchange 2010 DAG Witness Server Help Exchange Server Administration 2
S DAG Deployment Design with site resiliance Exchange Server Administration 2
H Shutdown all member in a DAG Exchange Server Administration 2
J DAG problem - I´m not able to recover database Exchange Server Administration 9
S Active Passive DAG seperate DNS namespace Exchange Server Administration 7
T DAG Exchange Server Administration 3
D DAG Failover Treshold Exchange Server Administration 5
J Roll Back Options for installing SP1 on a DAG Exchange Server Administration 5
P Failing whn adding a server to a DAG Exchange Server Administration 5
S Change IP on DAG and DAG Members Exchange Server Administration 2
S Exchange 2010 DAG design - Drp Exchange Server Administration 2
S Exchange 2010 DAG issue Exchange Server Administration 1
F Why is an unmounted Exchange Server hosting mailboxes after having configured a DAG but haven't brou Exchange Server Administration 9
Y Exchange 2010 with DAG into the same storage Exchange Server Administration 1
P DAG Question Exchange Server Administration 7
M Problem removing a mailbox server from a DAG. Exchange Server Administration 1
DAG
