iPhone sync issue with Outlook 2010
merlinmurph
I just upgraded to Outlook 2010
I use an iPhone
The iPhone will no longer sync with Outlook 2010 Contacts & Calendar
Is there a way to allow this to happen?
Sanwin2
Have you updated to the latest iTunes?
If so and still a problem then ask in the Apple forums. Outlook only holds the data, iTunes does all the synchronising.
V Sync Outlook contacts with iPhone Using Outlook 4
V Any alternative to iCloud for calendar sync to iPhone? Using Outlook 8
R Trying to sync my Outlook email on iphone Using Outlook 1
B iPhone Calendar will not sync with Outlook 2013 Using Outlook 0
E can't sync iPhone 4 with Outlook2010 Using Outlook 24
K outlook calendar wont sync iphone 4 Using Outlook 1
E Outlook 2013 calendar won't sync with iphone 4s Using Outlook 14
S Sync v2003 with iPhone/iCloud Using Outlook 5
V Sync Outlook 2003 calendar to iPhone 4 Using Outlook 2
V Sync iPhone 5 Using Outlook 5
S Using POP3, Exchange server, and iPhone sync - can't sync to POP3 calendar Exchange Server Administration 0
V Sync outlook with iphone after adding exchange mail account Using Outlook 2
R Outlook Connector wont sync with iPhone/iPad Using Outlook.com accounts in Outlook 1
L Cannot sync Calendar to iphone. Cannot export to CSV. Cannot view as Table. Using Outlook 3
P How to restore my previous address book after an iPhone sync changed it Using Outlook 2
M Sync Outlook 2010 Notes and Journal with iPhone 4 Using Outlook 1
K Is it possible to sync IPhone to BCM Outlook contact, calendars ... all data? BCM (Business Contact Manager) 16
C Does Microsoft Office 2011 for Mac sync the Task function in Outlook to an Iphone? Using Outlook 1
D Outlook 2010 and the Iphone 3Gs sync Using Outlook 3
J New Outlook on Mac Sync with iPhone Using Outlook 1
S Can you actually sync Outlook contacts & calendar with iPhone? Using Outlook 1
C MS Office 2007 calendar sync with new iPhone 4 won't work Using Outlook 1
S Can I sync to iphone with trial version of Outlook 2010? Using Outlook 1
S Syncing IPhone and Outlook - Restore previous sync Using Outlook 2
T Can't sync my iphone with my Microsoft Office 2010 calendar Using Outlook 1
V How can I sync my contacts and calender with iTunes/iPhone? Using Outlook 1
D calendar will not sync between iPhone 3GS v4.1 and Outlook 2007 using iTunes or MobileMe Using Outlook 3
O Outlook Calander Will Not Sync With IPhone... Help! Using Outlook 1
J sync outlook mail folders to my iphone Using Outlook 3
V One way problem = Iphone to PC sync problem Using Outlook 2
T sync a blackberry or iphone with outlook 07/MS exchange Using Outlook 1
S Missing file error when trying to sync iphone 3gs Using Outlook 1
L Outlook 2003 calendar -- sync problems b/t laptop and iphone. Using Outlook 1
P Sync iphone & contacts Using Outlook 1
V Outlook 2010: Some contact photos disappear after sync with iPhone Using Outlook 1
D cannot sync IPhone 4 with Outlook 2003. Using Outlook 1
T Can't sync with Iphone 4 and Outlook 2010 Using Outlook 2
Diane Poremsky Re: iphone cannot sync with outlook - Win 7 ... Using Outlook 1
T IPHONE 4.0 SYNC PROBLEMS Using Outlook 3
H I upgraded to Outlook 2010 click to run(64 bit) and now I can not sync with my iphone 3G. I have latest itune and iphone software. Apple says it is Using Outlook 1
J Public Calendars sync with iPhone Using Outlook 5
H Outlook e-mail and iPhone e-mail sync Using Outlook 3
E I need to Sync my Live contacts and Live Calendar (using outlook 2007) with iPhone 3GS Using Outlook 21
