AutoComplete is not seeing email addresses in Contacts
slinke
In freshly installed Outlook 2007, I have 330 people in my "Contacts" list. When I start typing in the "To" field, no names are suggested (until after I have sent an email to the person). This seems idiotic and broken.
Under "Advanced Email Options" the "Automatic name checking" and "Suggest names..." items are both selected. Under the properties for the "Contacts" folder, the "Show this folder as an Address Book" box is selected (and grayed out). I have tried deleting my "Outlook.NK2" file. I have tried addressing an email to everybody in my Contacts list, but then deleting it rather than sending it
In addition, there is another weird behavior. When I open "Address Book: Contacts" by going to Tools > Address Book, all of the people in my Contacts folder show up, but about 40% do not have anything under the "Name" or "Display Name" heading. Yet, if I open those contacts (properties), they have both names and display names, and there is no visible difference between the entries for the 40% that do no show them, and the 60% that do.
Outlook is a very messed up program.
slinke
After further review of the Outlook help file on AutoComplete, it seems that Outlook does not support automatic completing based on entries in the Contacts list. Since every other email program I have used has this functionality, I expected it to be available in Outlook. I guess I was wrong about this brain-dead program. Sorry to be so negative, but I have spent a frustrating couple of hours trying to figure this out.
autocomplete is just a list of people you recently sent messages to, not everyone in your contacts folder. If you want all contacts on it, open a new message, click To and select all names. Add them to the messages then close it without sending.
Automatic name checking is auto-resolution- as soon as you tab out of the field (if not before) outlook tries to match up the name you typed with a contact.
did you export your contacts to move them to the freshly installed outlook 2007? That can cause funny thing with contacts. If you edit the contact and save it, does the name show up in the Address book?
You need to add the addresses to the list. Honestly, i prefer not having all my contacts on the list - i don't send email to many of them more than once a year and having addresses i rarely use on the list increases the chances I'll accidently send them a message intended for others. But if you want all on your list, address a message to everyone then close it without sending.
slinke
Putting email addresses into an email, and then deleting it before sending does not add the names to the AutoComplete list. I have tried that several times. I even tried going into offline mode and hitting send prior to deleting the fake email. Does not work.
Yes, I imported the addresses from an Entourage for Mac export. Some of them show up as expected. Others do not have any Name or Display name. There seems to be no rhyme or reason for which ones worked. If I edit the Contact entries for the ones that lack the Name and Display Name data, it does not usually add the information (they are in the appropriate fields in the Contact, but they do not show up in the Tools > Address Book list). On a couple of contacts, when I tried this, it did add the Name and Display Name data. Again, though, there seems to be no rhyme or reason.
What a crazy stupid and inconsistent program Outlook is! I appreciate your efforts, though. Thanks for trying and taking the time to reply.
