Calendar entries
E
electrolite80
Is there a way for me to determine when a calendar entry was added to a calendar? I thought that there may be a properties feature, but did not find one.
E
electrolite80
Hi Diane:
Thank you for this, where do I go to find the created date option, I just need to check one date.
Steph
G
Guruprasad Ra
Open Outlook > Click on Calendar > Click on View > Current View > All Appointments > Right click on Subject Bar > Customize current view >Fields > Select available field from > change to date/time fields > Add created date > Click on OK.
By doing this you will be adding a new field which will show the created dates for all the appointments in Outlook calendar.
