Shared calendar "No connection" error
O
oluka
Our users are experiencing problems with Shared Calendars in Outlook 2010 connected to Exchange 2010.
The symptoms of this problem are like this. Users are using Outlook 2010 including Shared Calendars and after a while shared calendars start to show " no connection" status and users can't reach them anymore. Sometimes reboot helps and sometimes it doesn't.
Does anyone have any idea what is going on? Any suggestion how to troubleshoot Shared Calendar connections?
Luka Obersnu
Roady [MVP]
Are these shared calendar all located on the same Exchange server?
Are these clients to configured to cached shared folders?
When you look at the Send/Receive tab, is there an option which states; Connect to Server
Robert Sparnaaij
Sven De Bont
I'm experiencing the same issue. Things used to work fine, but I have the feeling the issues started after the exchange servers were upgraded to 2010
Some details on the setup.
I'm working on a stand-alone server (I do SharePoint development), not part of the domain. When I start Outlook, I have to enter my domain username & password which allows me to view my mailbox. I can however not see any shared calenders (or free/busy information)
Sven De Bont - MCAD http://blog.sdbonline.com
N
npins
I'm seeing this same sort of problem in a similar environment. Exchange 2010 (SP1 installed), with Outlook 2010 clients. Seemed to be fine for a few months, but now we're starting to see this issue. It seems random; different calenders for different people are coming up with the " No Connection" status.
There is only one Exchange server. I'll have to check if they are configured for cached folders or not, same with the Connect to Server option.
Update: I found that if users are granted Full Access as opposed to " Free/Busy Time" , they can see the calendar fine. Was able to get quite a few people working this way, and didn't run into any that it didn't work for. I didn't find a Connect to Server option, and most of them are not caching.
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
G Unable to dismiss reminders from share point list calendar shared in Outlook Using Outlook 2
C Outlook Shared Calendar Using Outlook 1
K Other Shared Calendar on Outlook cannot change items Using Outlook.com accounts in Outlook 7
Diane Poremsky Shared Calendar Can't Be Deleted New Slipstick.com Articles 0
A Get shared calendar name or id in custom appointment form Using Outlook 0
T Shared calendar not updating Using Outlook 1
Diane Poremsky How to View a Shared Calendar on a Smartphone New Slipstick.com Articles 0
J Auto Accept Notifications from a shared icloud calendar? Using Outlook 4
M Create an Appointment from XL Spreadsheet in a Shared Calendar. Outlook VBA and Custom Forms 1
F e-mail reminder for shared calendar Outlook VBA and Custom Forms 1
D Reminders in Outlook shared calendar Using Outlook 2
Z Reminders for all members of a shared calendar Using Outlook 1
M Email notification on creation of an appointment shared calendar? Outlook VBA and Custom Forms 3
Rory Campion Not getting a warning when a shared calendar item has been updated by someone else Using Outlook 2
N Outlook Shared appointments automatically to Private Calendar Using Outlook 1
I how to create appointment using saved template onto public folder shared calendar Using Outlook 3
Alex Hall When updating shared calendar, it does not automatically update personal calendar Using Outlook 3
J Creating an "isolated" shared calendar in Outlook Outlook VBA and Custom Forms 1
A Excel to Shared Outlook Calendar Using Outlook 1
T Shared Calendar usable from Intranet Using Outlook 2
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
M Open meeting in organizer's shared calendar Using Outlook 0
R New computer, OL2010 unable to display shared calendar appointments Exchange Server Administration 3
A Shared Calendar Outlook 2010 Using Outlook 4
T Setting Color codes for each user of a shared Calendar Using Outlook 1
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
S Some people can not see the contents of my shared calendar. Using Outlook 2
S Viewing shared calendar on smart phones Using Outlook 1
M outlook shared calendar data export to excel sheet Using Outlook 1
K Prevent meeting requests being sent from a shared calendar in a group mailbox Using Outlook 1
D Selecting shared calendar for appointment/meeting templates Using Outlook 2
L Shared calendar appointments received as emails, stays in inbox! Using Outlook 1
N Prevent reminder dismisal in shared calendar Using Outlook 1
E Shared Calendar Permissions Exchange Server Administration 4
C shared calendar reminders Using Outlook 6
J Oulook 2010 Shared Calendar Syncing Using Outlook 1
N Can't delete calendar entries on shared calendar Using Outlook 3
J [SOLVED] Shared Calendars with Same Appt., How to Show One Entry on Calendar Calendar Printing Assistant 1
R Shared Public calendar folder changing appointments Using Outlook 1
C Outlook Reminders for a Shared Calendar Using Outlook 9
J Cannot search items within shared calendar Using Outlook 0
S Shared Calendar Need To Stop Receiving Other Peoples Reminders Using Outlook 3
