program stuck in send mode, will not stop trying to send. now can't even get outlook to come up.
technotsavvy
Installed office 2010 and windows 7. set up outlook. now it's stuck on sending a message. cancel only makes it stop until the next log on. now can't even get outlook to come up.
Surya Prasad Vemulapalli
What happens when you try to open Outlook, do you get any error message?
Check if multiple instances of Outlook are open in task manager.
Right click on the taskbar on the screen click Task manager> check for any process by name Outlook.exe and end all the processes and then try opening Outlook.
You can also try creating a new profile in Outlook and check.
To create a new profile in Outlook, refer:www.support.microsoft.com/kb/829918
technotsavvy
No, I get no error message. I tried the end task, no change.
The problem started, I think, when I downloaded outlook express files into windows mail, then mailed them to outlook, then opened one. A dbx file.
Now e-mails can't be deleted. As soon as it's brought up, it goes to send mode.It takes forever to switch between folders ( inbox to deleted, etc. ) I can't send e-mails. Send recieve sends it back to stuck in send mode. The program simply isn't working properly.
Any other ideas?
technotsavvy
Creating a new profile seems to have solved the problem. A simple procedure to a vey confounding problem.
Thankyou very much, Surya.
T Outlook "A program is trying to access Outlook" Using Outlook 3
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
R SearchPublicFolders program Outlook VBA and Custom Forms 1
Diane Poremsky To Change the Default E-mail Program in Windows New Slipstick.com Articles 0
I There is no email program associated to perform requested action Using Outlook 0
J it goes like outlook has stopped working, a problem caused the program to stop working correctly, wi Using Outlook 2
J My Outlook program has stopped receiving. I can still send Using Outlook 1
C New version of MFCMAPI program Using Outlook 0
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
A outlook 2007 - there is no email program associated ... Using Outlook 3
F Default Program for Opening .pst Files ? Using Outlook 6
A Outlook-Program Not Closing Properly Using Outlook 10
B How to remove an old program from the Tools dropdown? Using Outlook 7
D How to set permissions to allow external program to send an email? Using Outlook 0
J A program is trying to access e-mail address you have stored in Outlook. Do you want to allow this. Using Outlook 2
J Outlook search index not saved - rebuilds every time I start the program Using Outlook 2
R Outlook 2007 cannot open files to start program Using Outlook 1
A Microsoft office home and business.Is there a 64 bit program?__ Using Outlook 2
K I have 26 mail in my webmail which is not coming in Outlook 2010 when I open the program.__some mail from my webmail has been loaded into Outlook when Using Outlook 2
F Outlook process won't end after I quit the program Using Outlook 2
M Outlook says the PST files is in use by another program - but it is not? Using Outlook 2
C For some reason, the program get's hung up after receiving mail. Using Outlook 2
K Windows7 + Outlook 2010: "Do you want to allow the following program to make changes to this compute Using Outlook 2
J How to change the program that Outlook assigns to open attachments Using Outlook 1
N When I try to import a large CSV from Excel to an Outlook folder, the program crashes... Every time. Using Outlook 2
T getting an error This file does not have a program associated with it for performing this action. C Using Outlook 7
M Change default program for opening email attachments. Using Outlook 1
J Problems trying to send attachemnt direct from Office program Using Outlook 5
P Home and Business, Business Contact Manager using passkey. Where can I find this program? Using Outlook 1
D What happens to the doccuments when you uninstall the Office 2010 Beta click to Run program in Vista OS? Using Outlook 3
S Outside Program trying to Access Outlook E-mail Using Outlook 2
E Outlook 2010 always focused as the main program in use Using Outlook 1
D Error Message: These files can't be emailed because there i sno email program on this computer Using Outlook 1
C How do I disable Outlook warning dialogue box "A Program is trying to send an e-mail message on your Using Outlook 2
D Error Message. files cant be emailed because theres no email program on computer Using Outlook 4
C Not receiving/sending email with Outlook (established program). Using Outlook 4
S All settings dropped and receiving Set up Wizard each time open program Using Outlook 1
P unable to use Send To Mail Recipient or from any other program to Outlook 2010 Using Outlook 2
A windows not detecting outlook pro 2010 64 bit as the default mail program Using Outlook 1
D my NK2 file will not up date. the last update was in August 2010. The program will not retain any Using Outlook 1
H Abnormal Program Termination Using Outlook 2
A Outlook 2010 version 14 downloads all messages from the server everytime you start the program Using Outlook 1
2 Placement of Exchange program files\databases\logs Exchange Server Administration 9
S Program shuts down when forwarding an email Using Outlook 1
N File attachment open in a program. Using Outlook 1
D tranferring information from profile to another using the franklin covey program Using Outlook 1
I Elimate unwanted email stored email addresses from Hotmail program Using Outlook 1
B Outlook 2002 (SP3): Even though I've checked 'Remember my password,' Outlook still requires that I enter it every time I open the program ea Using Outlook 3
