How to filter type of resource mailboxes for some cmdlet?
tsubusa
Hi All,
We have created several resource mailboxes in our envrionment, and we want to remove some cmdlet entries for all the resource mailboxes. For example, we do not want operators to execute "Set-CASMailbox" cmdlet to set the ActiveSyncMailboxPolicy for resource mailbox type from the exchange management shell. Could someone help provide some clue on this? Can it be configured from EMC or EMS?
Thanks in advance
tsubusa
mjolinor
You need to look at the permissions the operators have to the mailbox properties and settings and how to lock those down. Trying to prevent them from making changes by modifying the EMS or EMC is not going to practical or supported.[string](0..33|%{[char][int](46+("686552495351636652556262185355647068516270555358646562655775 0645570").substring(($_*2),2))})-replace " "
F
Frank.Wang
Hi tsubusa,
You can do it by RBAC which is a new permission mode for Exchange 2010.
Here is a simple step about how to do it:
1,Find which Role(eg: Mail recipients) including the cmdlet Set-CasMailbox.
2,create a new custom role based on the Mail Recipients.
3,modify the new custom role to remove the parameter ActiveSyncMailboxPolicy.
4,assign the new custom role to admin(or group or Role Group).
Details, suggest you read the Technet document:
Understanding Permissions
http://technet.microsoft.com/en-us/library/dd297943.aspx
Frank Wang
D Outlook 2007 AddIn: Filter attachments by type Outlook VBA and Custom Forms 2
B Task Filter Not Working When I add too many criteria Using Outlook 0
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
G How to filter by the format of an email address Using Outlook 6
S Mail filter recieved before the last 2 working days Using Outlook 1
Liza Creating a rule in outlook to filter messages Using Outlook 0
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
Diane Poremsky Filter and Save Contacts to a CSV File New Slipstick.com Articles 0
Fozzie Bear HomeTab Email filter "Greyed Out" in Outlook 2013 Exchange Server Administration 3
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
J Outlook VBA for Email Filter Outlook VBA and Custom Forms 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
M Filter today's mail Using Outlook 2
J Task Filter for Status OR One Month Using Outlook 4
R Filter Views by Category Using Outlook 2
D Junk Mail filter Using Outlook 1
S Filter by accounts but communicate to all linked contacts BCM (Business Contact Manager) 1
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
D How Would I Write This Filter? Using Outlook 3
N Filter end date works differently in OL'07/OL'10 vs OL'03? Hello?! Using Outlook 12
williamlambton Filter which removes Display Names from incoming emails. Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
L Need a good email filter Using Outlook 2
D How to manage and configure antispam updates for Hub Transport antispam filter agents at "filesystem Exchange Server Administration 1
S Edge Transport 3rd party mail filter before Exchange 2010 Exchange Server Administration 5
G OWA premium not working for new mailboxes - Corrupt restriction filter data Using Outlook 4
F Office 2010 Mail merge into Work 2010 using a specific Outlook catagory filter. Using Outlook 2
M Junk Mail filter not working for all blocked addresses Using Outlook 2
R Ignore Conversation - does it just filter on subject line? Using Outlook 1
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
M Rules will not filter my emails... Using Outlook 1
T using a filter to forward emails from a different account than the one that received them Using Outlook 5
G Outlook Junk Filter Settings Using Outlook 1
M Can one teach the Junk filter to check for entire words, not substrings? Using Outlook 1
F Inbox Count with Filter Using Outlook 1
D Create Receive Filter Exchange Server Administration 2
M How to disable Outlook 2007's junk mail filter? Using Outlook 10
E Gmail IMAP not working since installing junk mail filter update Using Outlook 1
M Greyed out Filter-EMail button Using Outlook 15
