Publish exchange HT with Forefront TMG without ET
MarekChmel
Hi folks,
can I publish my HT server (1 server, 1 site only) with forefront TMG 2010 without installing ET role?
Marek
Marek Chmel, WBI Systems (MCTS, MCITP, MCT, CCENT)
Shafaquat Ali
Did you mean CAS Server ?
If yes than the answer is yes.
Regards.
Shafaquat Ali.
M.C.I.T.P Exchange 2007/2010, M.C.I.T.P Windows Server 2008, M.C.T.S OCS Server 2007 R2, Phone: +923008210320
Tamer Sherif Mahmoud
for HT publishing that means you are talking about the SMTP traffic "mail flow" , so to publish HT through TMG yu will use the Mail server publishing wizard and select server to server communication then select SMTP standard port.
Also make sure to configure the SNAT on TMG to make hub server goes to internet with the MX & PTR configured IP.
Note: to configure SNAT define a computer object for the HT server on TMG and go to network relationships in TMG and create a new relationship between HT computer object and external network and choose the Public IP address that MX & PTR resloves to.
