cas array and mapi
C
Celtic1
I have said up a cas array name of casarray.domain.x for my two cas servers. I presume all mapi users connect to this virtual name. For the mapi users to connect thru a hwlb or wnlb what ports need to be opened to allow the mapi connection?
Celtic
P DNS Round Robin on CAS Array Exchange Server Administration 5
B After rebooting one of the cas array servers blackbarry stops working Exchange Server Administration 1
B cas array exchnage 2010 not working properly on vm Exchange Server Administration 5
S One CAS Array for mulitple site Exchange Server Administration 2
S CAS Array - NLB - Can't Ping VIP Exchange Server Administration 4
R accessing owa externally and having a cas array internally Exchange Server Administration 9
K CAS array SSL cert -RPC cas certificate warning Exchange Server Administration 3
S What to Use Instead a Hardware-based Load Balancer for an Exchange 2010 CAS Array Exchange Server Administration 21
R cas array owa is slow Exchange Server Administration 5
S Created CAS Array - Outlook certificate error Exchange Server Administration 2
S Exchange 2010 two datacenters two CAS array Exchange Server Administration 4
B Do we need to create a CAS Array for a single server site? Exchange Server Administration 3
M CAS Array Exchange Server Administration 6
R Installing SP1 on Hub/CAS servers in CAS Array Exchange Server Administration 9
R CAS array not working with Outlook Exchange Server Administration 15
B CAS Array article...? Exchange Server Administration 2
C Cas array question Exchange Server Administration 12
T Rename CAS array Exchange Server Administration 4
S CAS array legacy URL Exchange Server Administration 9
S CAS array in exchange 2003 and exchange 2010 coexsit environment Exchange Server Administration 4
S Looking for feedback on this CAS Array testing plan Exchange Server Administration 2
H CAS Array / OWA issues Exchange Server Administration 9
C CAS Array and Outlook Exchange Server Administration 3
C How to assign certificate(s) to an CAS array? Exchange Server Administration 1
C how should i assign an SSL certificate to a CAS array? Exchange Server Administration 2
Z Active SynC Issue in Exchange 2010 on CAS Array Exchange Server Administration 4
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
W CAS Array and Autodiscover for Internal and external access Exchange Server Administration 25
A NLB, CAS array or OTHER issue? Exchange Server Administration 24
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
L Cas Array failing when assigning using -rpcclientaccessserver Exchange Server Administration 3
R CAS Array Failover Issue Exchange Server Administration 17
K Outlook client on Exchange 2010 changes cas array name to instance-<guid> Using Outlook 21
B CAS Array with Hardware Load Balancers Exchange Server Administration 6
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
