Disable SSL requirement for Outlook clients
O
Oliver M
I have an Exchange 2007 server and 2 years ago I ran into the problem that Outlook clients got an SSL certifcate error when trying to connect, due to the difference in the internal and external servername.
I solved this problem by somehow disabling the need to have a SSL certificate on the Exchange 2007 server after which the clients could connect without an error.
I now installed a new Exchange 2010 server and am running into the same problem. How can I disable the SSL requirement to get the same solution?
Tom_V
Using IIS Manager you can remove the require SSL off of the Default Web Site.
In the Features view of the Default Web Site double-click on SSL settings and uncheck the require SSL and click on Apply. This change should propogate down to the other virtual directories.
MCITP: Enterprise Messaging Administrator 2007/2010 | MCITP: Server Administrator | MCTS: Windows Server 2008 Applications Infrastructure, Configuring | MCP | MCDST
O
Oliver M
Just tried it, but makes no difference.
When a user opens Outlook, they still get the certificate error....
TWHarrington
I have to ask the question...why not fix the SSL and configure Exchange the approprate way? Exchange 2010 is designed to work securely in every facet of operation. My advice is to buy a certificate (very cheap) and configure Exchange appropriately.
Jonas Andersson [MCITP]
I agree with Tim, godaddy.com have cheap certificates if you don't want to go for VerisignJonas Andersson MCTS: Microsoft Exchange Server 2007/2010 | MCITP: EMA 2007/2010 | MCSE/MCSA Blog: http://www.testlabs.se/blog
O
Oliver M
The reason is I really don't understand the use of certificates in Exchange.
- I now have a valid certificate for the IIS service, which assures that the OWA users don't receive a certificate error message. This certificate is isued to mail.externaldomain.com
- I also have a selfsigned certificate for IMAP, POP, SMTP service. This certificate is isued to mail2.internaldomain.com
What do I need to do to assure that Outlook clients won't receive an error message?
TWHarrington
So the pop-up you are seeing is for the autodiscover service. Outlook is hardcoded to look for this service with a specific name: autodiscover.smtpdomain.com. The best way to handle this is getting a UC/SAN certificate and including both your mail.externaldomain.com and autodiscover.externaldomain.com. IF you don't want to mess with that, you can get by with a single name certificate, but you need to configure Exchange appropriately and set up some SRV DNS records. This link should help:
http://www.amset.info/exchange/singlenamessl.asp
O
Oliver M
The following problem arrises now.
I own a ssl certificate for mail.externaldomain.com, I tried to order a ssl certificate for mail.internaldomain.com but I am not allowed to purchase that because we don't own the *.internaldomain.com.
In order to workaround this problem I changed the autodiscover url to mail.externaldomain.com, and this way the ssl error disappeared, but the clients now have to login everytime they open the Outlook client....
How can I resolve this problem??
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
N How to disable shortcuts for Pilcrow in Outlook Using Outlook 0
P Disable Spam Notifications & Sounds Using Outlook 3
Diane Poremsky Disable Protected View for Outlook Attachments New Slipstick.com Articles 0
Diane Poremsky Disable Outlook Add-ins (Apps) New Slipstick.com Articles 0
J Using VBA to disable alerts / warnings Using Outlook 2
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments New Slipstick.com Articles 0
N How to disable user defined fields in BCM forms Using Outlook 2
Diane Poremsky Disable Live Preview in Outlook and Word New Slipstick.com Articles 0
D Preventing users to disable an Outlook Add-in Using Outlook.com accounts in Outlook 5
F Disable "Find related messages" Using Outlook 1
davecazz Anyway to disable the peek rollovers? Using Outlook 1
R Outlook Cache Mode Terminalserver disable through Registry Using Outlook 1
S Cannot disable OWA light Exchange Server Administration 5
A How to disable the pop-up “Reponses to this meeting will not be tallied." Using Outlook 0
D Show this folder as an e-mail Address Book is enabled but I want to disable Using Outlook 2
Rupert Dragwater how to disable billingual dictionary in outlook 2010 Using Outlook 9
J How to disable syncing folder views/layouts Using Outlook 5
A Disable hotmail from Outlook email account Using Outlook 1
R Disable request to share a calendar Using Outlook 1
T Disable the To-Do Bar permanently Using Outlook 15
J Outlook's auto time zone update for meeting requestsHow to REMOVE or DISABLE? Using Outlook 1
D Disable Junk Email in the Registry? Using Outlook 8
D Disable Read Receipt Request for specific e-mail address Using Outlook 1
M cannot disable autoconfiguration popup/message in outlook 2007 Using Outlook 2
J Exchange 2010 + Disable ActiveSync/Outlook Anywhere/POP/IMAP/ By Default Exchange Server Administration 5
G Disable Outlook Web Access Password Expiry Notification Banner Using Outlook 4
M Is there a Step-by-Step how-to Disable and Attach a Mailbox to a Different User for Exhange 2010? Exchange Server Administration 4
E Outlook 2010 - Disable team calendars? Using Outlook 1
S Outlook 2010 PST Are disappering, Disable JunkMail ? Using Outlook 1
A How to disable bcc option in GAL - Address Book - Exchange 2007 Exchange Server Administration 4
J How do I disable the message: The contents of this appointment have been updated. Using Outlook 1
J CONTACTING SERVER...Message on Printing and forwarding certain html rich mails . How to disable. Using Outlook 3
P How to disable unwanted encoding in Outlook 2010/Exchange 2007? Using Outlook 4
P Exchange 2010 SP1 Cross Site CAS connection disable Exchange Server Administration 2
E Can't disable nuance pdf add-in Using Outlook 3
M i can't Disable Junk E-Mail filtering on a specific user mailbox Exchange Server Administration 1
K When printing an email the printer goes to manual feed every time. How do I disable this in Office Using Outlook 2
L OWA 2007 disable autocomplete Using Outlook 3
C How do I disable Outlook warning dialogue box "A Program is trying to send an e-mail message on your Using Outlook 2
D Remove or Disable Suggested Contacts Using Outlook 3
