Exchange 2010 and third party certificate
C
Chris Vavrek
Recently installed a third-party cert on my exchange 2010 and everything works fine from outside the building. When users connect internally though I do not have the fully qualified domain of my Exchange server included. Therefore I get the error 'The name on the certificate is invalid or does not match the site' When I startup Outlook I do not get this message but it occurs when I go to send a new message.
I reviewed a MSFT that was directed to Outlook 2007 clients and Exchange 2010 but we will not have any Outlook 2007 clients.
Should I redo my cert with the fqdn or might someone have another suggestion?
Thank You
Chris
TWHarrington
You can update intenal DNS and the all the internal CAS URLs to point to the same FQDN that is on your cert. Change the DNS to use the internal IP of the CAS.
C
Chris Vavrek
It seems as though I am now only getting the message when I try to send a new message or click File...
TWHarrington
That seems a little bizarre. Can you recreate your profile from scratch? Are others having the issue? Does your profile get created automatically with AutoDiscover or are your manually creating it? What version of Outlook with SP version are you using?
Brian Desmond -MVP-
Can you post the names in the certificate as well as the output of Get-ClientAccessServer | fl *uri* ? What version of Outlook are you using?
Active Directory, 4th Edition - www.briandesmond.com/ad4/
Richard Pollock
One thought would be to get a certificate with subject alternative names. You can list all possible domain combinations in your SAN Cert...
B Exchange 2010 archiving vs third party Exchange Server Administration 12
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
R Create a contacts list on Exchange 2010 Exchange Server Administration 10
T Exchange / Outlook 2010 - How to cancel meetings but retain the calendar entry Using Outlook 4
S Outlook Quick Steps - Exchange 2003 / Exchange 2010 Exchange Server Administration 2
R Sharing Exchange 2010 calendars with people outisde our organization Exchange Server Administration 17
A Exchange 2010 Outlook 2010 and Local Failures sync issue Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
U Exchange 2010 & mailbox database Quotas Exchange Server Administration 1
T Outlook 2010/Exchange 2003: Meeting Organizer doesn't show Using Outlook 1
C Outlook/Exchange 2010 Recover Deleted Items to original folder Using Outlook 2
D large mailbox question using 2010 on exchange 2k3 Exchange Server Administration 2
R Change Outlook 2010 Exchange server address via registry or script Using Outlook 5
