best practices for the reading pane
jlongjr
I'm not finding too much info on the reading pane, weather or not it's best to leave it available or disable. I'm using outlook 2007 with exchange 2007 sp1. I currently leave it up to the end users and I personally have it turned off. My IT assistant does use it but he wasn't in the IT field back in the late 90's or early 00's when it was considered a best practice.
Here is what happened. There was a nicely crafted email with an attachment called invoice.html. That was the first email in the this users inbox and the reading pane is on. That user simply clicked once on the attachment and was immediately infected with fake AV. I have since blocked htm and html attachments on our email scanning server. I have also contacted our security vendor to see why this wasn't blocked.
I know in the past it was common to disable the reading pane or preview pane but haven't heard much about it lately. I also know that the reading pane wasn't directly responsible for the infection. I just think that the user would have thought twice about clicking on the attachment if they had to open the email. Maybe I am giving the user too much credit at that point though.
Maybe it's time to implement a proxy server. Damn you hackers!!!
Also slightly off topic of outlook, when a computer is infected I first unplug it from the network and scan using various tools to find as much of the infection and source as possible. Then I format the hd and reimage the system. What do you all do when you find an infected compuer?
James-Luo
For the best practice for the reading pane, please use the “Office IT Pro” forum which would be the better place for seeking suggestions
For the .htm/.html attachment, you can also use the attachment settings to block them
Customize attachment settings in Outlook
How to configure Outlook to block additional attachment file name extensions
James Luo
TechNet Subscriber Support (http://technet.microsoft.com/en-us/subscriptions/ms788697.aspx)
If you have any feedback on our support, please contact tngfb@microsoft.com
S CAS/MBX reboot best practices. Exchange Server Administration 7
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
B How to set up all Staff Calendar - Best Practices Using Outlook 2
C Best Practices For Subject Alternative Names On Your Exchange 2010 SSL Exchange Server Administration 11
J Best Practices - domain names for internal and external Exchange Server Administration 5
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B What Card Scanner is best to use w/Outlook 2010? Using Outlook 1
F Best Recovery Tools! Exchange Server Administration 3
S Best way to Segment my data base please? Using Outlook 1
D Best Method to Merge two companies Exchange environments one is on Exchange 2007 and the other on Exchange 2010 Exchange Server Administration 2
A How best to handle shared email folder where history needs to be maintained Using Outlook 2
