customize contacts
rthomes
I see where you can add extra info in the user definer fields, but once I add it where does it show up at. and can I customize the fields already there. And how do I show only contacts for certain categories, oh also a number of times trying to add a category my computer locked up
N
Natasha Dsouza
Open Outlook > Go to the contacts folder > Click on the View tab > Select view settings > Click on Columns to add or remove display fields.
To sort according to categories in the View tab Select categories.
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
Diane Poremsky Customize the Outlook Toolbar, Ribbon or QAT New Slipstick.com Articles 0
M Customize CreateItemFromTemplate Macro Outlook VBA and Custom Forms 2
Ankit Agrawal Customize themes in outlook 2010 Using Outlook 1
M please customize this code Using Outlook 1
G Customize Outlook Today folder Using Outlook 0
C Anyone found a way to customize search? BCM (Business Contact Manager) 5
P How may I customize with an own immage a standard email Using Outlook 6
D In Outlook 2007 on Windows 7 64 bit Customize Current View 'Other Settings' Fonts changes do not hold Using Outlook 2
K Can I customize OL2010 month view calendar to be more legible; skip confusing colors and show more a Using Outlook 1
W Customize accounts (folderlist) in navigation pane Using Outlook 5
J Customize Outlook view to fit Smartphone display via i.e. Citrix Receiver ? Using Outlook 1
M Customize Current View of PST Files Using Outlook 2
P Customize Appointment Form Using Outlook 1
U How to customize exch 2010 smtp bounced msg like 5.7.1 or 5.7.11 Exchange Server Administration 2
S Customize Text on OWA Change Password Form Exchange Server Administration 3
J How to customize the To-Do list to show items from only one specific mailbox? Using Outlook 2
J The filter Button is dimmed in the View - Customize Current View dialog. Using Outlook 2007 on Exchange. Using Outlook 3
C Customize Themes Exchange 2010 SP1 Exchange Server Administration 4
K OWA 2010 - Any way to customize the Calendar Sharing Invitation? Exchange Server Administration 1
A Customize Colours Using Outlook 1
G BCM 2007 Customize Current View not sticking Using Outlook 2
C Customize Current View - Group By & Remove This Column Using Outlook 2
A when i customize new fields in the contact menu, it displays under define fields but does not display when trying to imput a new contact. Using Outlook 1
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
R How to implement customize toolbar in outlook? Outlook VBA and Custom Forms 1
N How to add fields to customize reports in BCM? BCM (Business Contact Manager) 3
J Outlook 2013 Change color of text in data fields of contacts in Outlook 2013? Using Outlook 3
GregS Exporting contacts Using Outlook 1
