Roaming AutoComplete Lists, how to turn it off?
Milo145
Roaming AutoComplete Lists is a great idea except when the list is pulled to your PDA. Can this funcationality be turned on/off and if so per device?
F
Frank.Wang
Hi Milo145,
The autocomplete lists are stored as "Suggested Contacts".
You can navigate to Contacts->My Contacts->Suggested Contacts.
To turn off the function in Outlook 2010:
File->Options->Contacts->Suggested Contacts->clear "Automatically create Outlook Contacts for Recipients..."
But you should delete existed contacts in the Suggested Contacts manually.
Frank Wang
Milo145
Frank:
Thank you for your reply. I'm looking to retain the funcationality locally on my workstation but turn it off server side. The reason is because my Droid2 running Android 2.2 is pulling my autocompletes into the devices contacts. Any ideas?
TIA
A I have a roaming profile and when I delete emails from one computer Using Outlook 1
N Email Stuck in Outbox - Cached Mode - Roaming Profile Using Outlook 2
S Cached Exchange Mode and roaming users Using Outlook 5
J Using roaming profile wiht Outlook Anywhere Using Outlook 3
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
V Autocomplete not working on new email account Using Outlook 4
G Autocomplete adds suspicious "@unknown.email" to selected contacts Using Outlook 1
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
M email autocomplete broke.. Using Outlook 5
C Autocomplete losing some (not all) addresses Using Outlook 6
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
V Outlook 2013 - transfer autocomplete data Using Outlook 4
A Autocomplete issue Using Outlook 6
Michael Durthaler Outlook 2013 Autocomplete File Is Infected Using Outlook 1
U Autocomplete not working Using Outlook 5
S Recover Autocomplete After Computer Failure Re-install Using Outlook 3
G Outlook 2013 AutoComplete Limit Using Outlook 3
O Add please, Outlook Autocomplete working per account in multi profile ! Outlook Wishlist 5
Z Copy Outlook 2007 "AutoComplete Contacts” to Outlook 2010 Using Outlook 7
J autocomplete in "To" field does not work for display names Using Outlook 8
U Imported contacts to appear in Autocomplete Using Outlook 1
V Outlook 2010 Autocomplete Using Outlook 7
N Outlook should use address in address book before the address in Autocomplete Using Outlook 0
A Help with random numbers in autocomplete emails Exchange Server Administration 3
K Autocomplete list not saving distribution list Using Outlook 3
H can not get autocomplete on Using Outlook 2
S Autocomplete entries wiped out when I exit Outlook 2010. Using Outlook 12
R Help migrating Autocomplete contacts, from Outlook 2003 to windows live mail. Using Outlook 2
B Outlook 2010 - AutoComplete not working properly Using Outlook 1
I Outlook 2010. Autocomplete expired or what? Using Outlook 2
R Outlook 2010 Autocomplete Using Name Rather Than Email Address Using Outlook 2
L OWA 2007 disable autocomplete Using Outlook 3
P Outlook 2010 autocomplete clears the cache when exiting Outlook Using Outlook 1
L Outlook 2010 Autocomplete not working Using Outlook 5
S Autocomplete has not worked since I got my new computer a month or so ago. How do I fix it so the emails are stored for autocomplete? Using Outlook 1
S AutoComplete addresses lost in Outlook 2010 Using Outlook 1
G Autocomplete: How do I turn it back ON for Outlook 2010? Using Outlook 1
G Autocomplete: How do I turn it on? There is a large existing address book. Using Outlook 1
V outlook 2007 autocomplete not working when typing in addresses Using Outlook 3
D Disable Autocomplete in OWA 2010 for ALL users? Exchange Server Administration 5
C Outlook 2010 stopped retaining address autocomplete data Using Outlook 8
C Outlook 2010 autocomplete not retaining data Using Outlook 13
L Outlook autocomplete sort order Using Outlook 3
S Transferring AutoComplete List Using Outlook 5
D Autocomplete doesn't retain the database after Outlook 2010 is restarted. Using Outlook 1
D Autocomplete in Outlook Using Outlook 4
N Outlook 2010 Autocomplete not working Using Outlook 6
P Autocomplete not functioning on Outlook 2010 Using Outlook 4
