How to make attachments display as icons on the header and not in the body of the message - when sen
  • Thread starter RandomDisplayName200
  • Start date
I have seen plenty of discussions on MS sites and elsewhere about getting attachments to not display in the body of an email. But all of those discuss an Outlook user sending to an Outlook reader, and the sender was not supposed to use Rich Text Format.
But in my case, the email is sent from an HP-UX system with sendmail. A text file is passed through uuencode to sendmail and the destination email address. The receiver is seeing the attachment in the body of the email. This happens to some Outlook 2007 users, but not all. Have gone into every Outlook client setting to try and find why it works for some and not others. The HP-UX system is sendign it as " Content-Type:text/plain" .
Is there any change to user settings that can change this behaviour ?
There is not a user controlled setting for this. Attachments should be in the header unless the message is RTF formatting or the message is corrupt.
Does the outlook user get it as plain text and is the attachment included as part of the message text or an icon in the message body?
J Attachments - Display attachment name and date rather than name and file size Using Outlook 1
A Attachments.Delete Outlook VBA and Custom Forms 3
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
R fetching blocked attachments Outlook VBA and Custom Forms 0
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
R Outlook is NOT removing attachments. Using Outlook 4
Dan_W Nested email attachments Outlook VBA and Custom Forms 4
S DRAGGING MAIL AND ATTACHMENTS TO CALENDAR Using Outlook 1
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
I Forwarding attachments in email received Outlook VBA and Custom Forms 3
M Outlook 2016 msg attachments Using Outlook 0
M Macro for attachments download adjustment Outlook VBA and Custom Forms 3
Diane Poremsky Save Messages and Attachments to a New Folder New Slipstick.com Articles 0
B Delete/replace old files and save new attachments Using Outlook 1
Diane Poremsky Disable Protected View for Outlook Attachments New Slipstick.com Articles 0
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
Diane Poremsky Outlook is sending winmail.dat attachments New Slipstick.com Articles 0
Diane Poremsky Edit and Save Outlook's Read-Only Attachments New Slipstick.com Articles 0
J Forward Message after editing attachments and include edited attachments Using Outlook 5
Diane Poremsky Save Attachments to the Hard Drive New Slipstick.com Articles 2
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
