Auto Save as Text
bclick
Office 2010 on Windows 7 64bit:
I would like to have incoming messages from a certain sender automatically Saved as Text to a directory in the Windows file system. Any way to do this? Thanks!
R Outlook 2013 VB rule to auto save attachments with different file types Outlook VBA and Custom Forms 5
J Auto-Save for Outlook Calendar Entries Using Outlook 5
F Stop Address Auto Save Using Outlook 1
P transfering auto-save names from microsoft outlook EMAIL when LOADING to a new computer Using Outlook 2
E Auto Save Zip File Attachment to Network Folder Outlook VBA and Custom Forms 1
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 6
