Create corresponding ECP
  • Thread starter Matthew Arkin [MVP]
  • Start date
Matthew Arkin [MVP]
I'm having a couple OWA issues.
I'm trying to create an OWA site under a New Site in IIS (this is because I want my end users to be able to access owa through a subdomain, but I need my offisite IT folks to be able to access ECP so the redirection wouldn't work if I left it all in the same IIS site).
After I create the new OWA site, it tells me I must create a corresponding ECP site (when I try to do it, I can't figure out the correct Identity it wants me to use (sorry if thats a noob question).
Right now if I try to access the OWA page it give me a 500 internal server error.
Matt
Matthew Arkin - Microsoft Partner - http://twitter.com/Microsoft_Cares - All posts are "as is" without warranty of any kind, either expressed or implied
Tom Vanopoulos
In the shell try the following commands. The first is creating the OWA vir dir and the Second is creating the ECP vir dir.
New-OwaVirtualDirectory -NewWebSiteName "Website Name"
New-EcpVirtualDirectory -Identity "Server_Name\ecp (New Web Site Name)"
Regards,
Tom
MCITP: Enterprise Messaging Administrator 2007/2010 | MCITP: Server Administrator | MCTS: Windows Server 2008 Applications Infrastructure, Configuring | MCP | MCDST
Matthew Arkin [MVP]
Thanks Tom,
I was able to set up the OWA Directory in a new site, but when I try running the Ecp commands it tells me that
Cannot process argument transformation on parameter 'DomainController'. Cannot convert value "WIN-BPES89UC4SA\ecp (Exch
ange1)" to type "Microsoft.Exchange.Data.Fqdn". Error: ""Server Name\ecp (Exchange1)" isn't a valid SMTP domain."
+ CategoryInfo : InvalidData: :)) [New-EcpVirtualDirectory], ParameterBindin...mationException
+ FullyQualifiedErrorId : ParameterArgumentTransformationError,New-EcpVirtualDirectory
I've tried the fqdn as well as just the servername
Tom Vanopoulos
Try typing Get-ECPVirtualDirectory what does the output show. By default it should show the following:
Name Server
---- ---- ecp (Default Web Site) <Server_Name>
Try the following command and match the Server Name as the above output:
New-EcpVirtualDirectory -Identity "<Server_Name>" -name "ECP" -WebSiteName "New Web Site Name"
Regards,
Tom
Matthew Arkin [MVP]
With New-EcpVirtualDirectory -Identity "<Server_Name>" -name "ECP" -WebSiteName "New Web Site Name", it told me I needed to add the External and Internal Urls and now it wants me to add the path, which is?Matthew Arkin - Microsoft Partner - http://twitter.com/Microsoft_Cares - All posts are "as is" without warranty of any kind, either expressed or implied
Tom Vanopoulos
If the ECP directory has been created then you can type the following:
Set-EcpVirtualDirectory -Identity "<Server_Name>\ecp (New Web Site)" -ExternalURL "https://<URLforExternalAccess>/ecp" -InternalURL "https://<URLforInternalAccess>ecp"
If it hasn't been created then you can type the following:
New-EcpVirtualDirectory -Identity "<Server_Name>" -name "ECP" -WebSiteName "New Web Site Name" -ExternalURL "https://<URLforExternalAccess>/ecp" -InternalURL "https://<URLforInternalAccess>/ecp"
Let me know how it goes.
Regards,
Tom
C Can't create Outlook data file Outlook Wishlist 0
Diane Poremsky Create a Task when a Message is Flagged New Slipstick.com Articles 0
Diane Poremsky Create a custom field for Outlook messages New Slipstick.com Articles 0
Mark White vba to create a shared mailbox folder Outlook VBA and Custom Forms 3
Diane Poremsky Automatically create a task when sending a message New Slipstick.com Articles 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages New Slipstick.com Articles 0
Diane Poremsky Create a Series of Tasks using VBA New Slipstick.com Articles 0
J create .pst data file for new gmail account Using Outlook.com accounts in Outlook 1
Diane Poremsky Create an Organizational Forms Library New Slipstick.com Articles 0
Diane Poremsky Create an Organizational Forms Library in Exchange 2013 or Office 365 New Slipstick.com Articles 0
Jeanne Goodman Create Printout from Multiple Shared Calendars Outlook VBA and Custom Forms 8
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
Diane Poremsky Create Appointments Using Spreadsheet Data New Slipstick.com Articles 0
A VBA to create meeting from template from a time slot selected in someone's calendar Outlook VBA and Custom Forms 5
G Create an Appointment at the Contact's Address From Email Outlook VBA and Custom Forms 0
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender New Slipstick.com Articles 0
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
M Automatically create event in calendar when task is created Outlook VBA and Custom Forms 1
