Outlook 2010, save to ics and no subject and description when re-open again
sarajung
I use Outlook 2010, 64 bits om Windows 7, 64bits, when I save calendar as a file ICS and try to re-open again with Outlook 2010, I found that no subject and details (description) in calendar.
After I open file ICS as a notepad, I cannot find any text of subject and details.
How can I do?
Sara
Ruchi Bisht
Saving the calendar as ics will save information on the default date that is selected in the calendar. If that date does not contain any entry, it will not reflect any information while importing the calendar.
Choose the dates manually while saving the calendar and check if that works.
Ruchi Bisht
Adam Vero - MCT, MMI, MBMSS-CRM, MCSA-M
Are you opening an individual calendar entry and going to File > Save As, or are you using the option to Save Calendar?
If you "Save Calendar" for a day with no entries, you should get a warning about this. If you choose to continue anyway, you will get a blank ics file, as expected.
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
E can't save draft email in Outlook 2010 Using Outlook 2
F CAN'T SAVE OUTLOOK 2010 E-MAIL TEMPLATE (.oft) Using Outlook 1
Rupert Dragwater Can't save font type in Outlook 2010 Using Outlook 3
S Outlook 2010: Cannot save forms templates to folder list Using Outlook 4
N Save new contact from inbox to contact subfolder in Outlook 2010 Using Outlook 1
S Outlook 2010: Save POP email to Exchange mailbox?? Using Outlook 3
T Outlook 2010 does not save "sent" messages Using Outlook 1
C Outlook 2010 & windows 7 - WILL NOT SAVE emails on the server. Using Outlook 1
A Outlook 2010 trying to create calendar/task entries generates error "Could not save item.The connect Using Outlook 2
S Outlook 14 lose contact with our exchange server 2010 after Windows 7 have been in power save mode. Using Outlook 2
A Outlook 2010 trying to create calendar/task entries generates error "Could not save item.The connect Using Outlook 1
R Outlook 2010 does (partial) not save to NormalEmail.dotm? Using Outlook 1
A Outlook 2010 won't save passwords Using Outlook 3
G Where does Microsoft Outlook 2010 save my information and configurations? Using Outlook 1
I Outlook 2010 Quick Steps Don't Save (Global Address Book) Using Outlook 3
D Changing the default "save to" for attachments in Outlook 2010 Using Outlook 7
B Outlook 2010. Can't save contacts, appointments and tasks. Using Outlook 6
Z Folder to save new conntact Outlook 2010 Using Outlook 2
M Outlook 2010 asks me "Do you want to open or save this file?" when I first run it. If I open, it con Using Outlook 3
M I am unable to save my Outlook 2010 calendar (64-bit) to either an ics or cvs file. Using Outlook 1
O Outlook 2010 refuses to start in normal mode. Only works in Safe mode. Cannot save any of my setting Using Outlook 1
C Default Reminder change in Outlook 2010 won't save. Using Outlook 2
F Exchange 2010 rollup 3 and Outlook 2007 sp2 Can't save attachments Exchange Server Administration 14
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
