Best way to Segment my data base please?
SpeedySpiteri
Hello, some guidance please. I have Outlook 03 Business Contact Manager. I would like to use it for marketing and reports. Can you tell me what is the best way to segment my data base
Should I use categories or user defined fields??
Can I enter user defined fields in BCM 03?
Angie
Ruchi Bisht
Well, you can use both categories and User Defined fields to segment the database.
However User defined fields will be more helpful to segment the data base.
Ruchi Bisht
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
Horsepower Email best practice Using Outlook 3
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
F Best Non MS Exchange 2010 book for beginners? Exchange Server Administration 7
S CAS/MBX reboot best practices. Exchange Server Administration 7
I Best Practice for Large Messages NDRs? Exchange Server Administration 4
L best rule/macro to send emails from many people/orgs to same folder Using Outlook 3
R Any "Best Practices" for a test/developer Exchange 2010 server? Exchange Server Administration 2
C Best way to effectively back up Outlook Calendar (and save Categories) and Email as well???? Using Outlook 6
R Best practices for creating "Equipment" mailbox resources? Using Outlook 1
D Exchange Best Practice for DEV/TEST/PROD Exchange Server Administration 2
M Exchange 2010: What to monitor - best practices Exchange Server Administration 4
K Best case scenerio to reduce disk space usage Exchange Server Administration 5
B What Card Scanner is best to use w/Outlook 2010? Using Outlook 1
F Best Recovery Tools! Exchange Server Administration 3
D Best Method to Merge two companies Exchange environments one is on Exchange 2007 and the other on Exchange 2010 Exchange Server Administration 2
B How to set up all Staff Calendar - Best Practices Using Outlook 2
J best practices for the reading pane Using Outlook 1
A How best to handle shared email folder where history needs to be maintained Using Outlook 2
D Exchange 2010\Outlook 2010 - Mailbox size best practice? Exchange Server Administration 3
D Domain has an unknown Exchange signature (Best practice analyser on exchange 2010) Exchange Server Administration 4
