Calendar printing assistant for Outlook 2010 (32bit)
Mangomama
I downloaded the calendar printing assistant, but when I try to insltall it, I get msg to close Outlook (which is closed) and the install hangs up. Usig Win 7 and Office Prof 2010 (32 bit)
How can I get it to install? I was using it with Vista and Outlook 2007 and really need the program back. I also checked the Installed programs and there is not the previous Printing Assistant listed.
Mangomama
Thanks for the link. I re-downloaded it and then made sure Outlook was unpinned from the task bar. I shut the computer off and when I rebooted, the first thing I did was to install the program and I didn't get all the error messges. It installed as a separate program and not as an add-in to Outlook.
Thanks again.
Pinning wouldn't make a difference, but it sounds like something is keeping outlook running after its closed. This is usually caused by an addin or program that accesses outlook data.
In any event, glad it finally worked for you.
M Calendar Printing Assistant Hangs only on specific Template Using Outlook 2
S So Disappointed in Calendar Printing Assistant!! Calendar Printing Assistant 2
E Adding Start and End Time to Daily View in Calendar Printing assistant Calendar Printing Assistant 1
P Printing Issue on Calendar Printing Assistant Calendar Printing Assistant 0
J Ho do I hide the week number on the Calendar Printing Assistant template Calendar Printing Assistant 4
B Can't install Calendar Printing Assistant - Windows 7 64bit&Office 2010 32bit Calendar Printing Assistant 2
A Emailing Calendars Created in Outlook Calendar Printing Assistant Calendar Printing Assistant 3
C Calendar Printing Assistant for Outlook 2010 Using Outlook 2
D Old recurring appointments showing up in Calendar Printing Assistant Using Outlook 6
A Cannot Turn off end date in Calendar Printing Assistant Using Outlook 1
D Trouble downloading Calendar Printing Assistant for Outlook 2010 Using Outlook 2
H How to print multiple calendars using calendar printing assistant Using Outlook 1
R 2010 Calendar Printing Assistant Month View Using Outlook 1
G Using Outlook Calendar Printing Assistant in Outlook 2010 Using Outlook 6
S Outlook 2007 Calendar Printing Assistant-Erron Printing Tasks Using Outlook 1
W Calendar Printing Assistant Using Outlook 1
A Calendar Printing Assistant - not using category color codes except in full day events Using Outlook 1
Forum Admin Calendar Printing Assistant v2 Calendar Printing Assistant 0
T Printing problem in Calendar Printing Assistant Calendar Printing Assistant 3
M Calendar Printing Assistant that Works & is Supported Outlook Wishlist 1
Y Outlook 2010 or Calendar Printing Assistant Calendar Printing Assistant 2
V Calendar Printing Assistant Crashing on Me Calendar Printing Assistant 1
T Calendar Printing Assistant Crashes - Cannot Uninstall Calendar Printing Assistant 8
Q Calendar Printing Assistant Calendar Printing Assistant 2
P printing weekly calendar in Outlook 2013 cuts days of week off Using Outlook 1
K calendar printing Using Outlook 1
J Printing Calendar in Outlook 2013 Using Outlook 0
E Monthly Style Calendar Printing Using Outlook 6
P Printing calendar (work week) with numerous (i.e. >7) all day events... Calendar Printing Assistant 3
A Outlook CPAO - Printing Monthly calendar with only all day events or catergory Calendar Printing Assistant 2
S Printing Category Key on Calendar Using Outlook 1
W Calendar Printing with Outlook 2010 (64 bit) Calendar Printing Assistant 1
R printing custom number of calendar days in weekly view format Using Outlook 1
D Printing Monthly Calendar Using Outlook 2
J Calendar Pop-up Missing from Calendar Printing Dialogue Using Outlook 1
C Printing a monthly calendar in overlay view Calendar Printing Assistant 3
J Printing Private Appointment Detail on Calendar Printing Assistance Calendar Printing Assistant 0
J Microsoft Outlook Calendar - end time of appointment has started printing but don't want it to print Using Outlook 2
D Printing calendar - Change color of meeting time Using Outlook 1
S Labels Not Printing on Calendar Calendar Printing Assistant 3
H Is there an easy way to set the date range when printing a calendar? Using Outlook 1
B Outlook 2007 Calendar Printing with large font Using Outlook 1
J Outlook not printing October 23-31 in Calendar Using Outlook 1
F Calendar printing and print preview differs from screen view Using Outlook 1
B Calendar Printing only prints two lines Using Outlook 3
J Calendar appointment details will not show when printing Using Outlook 8
E Printing my Calendar in Outlook 2010. Using Outlook 2
P Calendar printing too much detail Using Outlook 1
B printing a calendar on a single page using CPA Calendar Printing Assistant 0
A Outlook 2007 Calendar month view printing with word wrap - cutting words in the middle Using Outlook 5
