Re: problems moving mails between folders
Brian Tillman
This could be a view issue, with your view hiding the messages even though they are actually in the folder. Try starting Outlook once with the /cleanviews command switch. Press WinKey+R and in the Open field, enter
outlook.exe /cleanviews
Be sure to include the space. Press Enter.
Jaime Cabrera
well , i tried in your way but still cannot see my emails but now if i move other new emails now i can see them but the old ones still cannot
A Problems with moving msg files to network folder Using Outlook 3
F Migrating to Outlook 2010...moving from .pst to Mailbox...problems Using Outlook 1
J Problems after moving Outlook.pst file from dead XP pc to new Win7 pc. Using Outlook 13
C problems Using Outlook 1
