Outlook 2007 dialog box font too large, contents truncated
MeatSim
When I open a dialog box (e.g. Tools > Options) in Outlook 2007, the font is too large and some of the content is cut off. I can't see all the content, because the dialog box will not resize. I'm using Windows XP Professional version 5.1, SP3.
G
Guruprasad Ra
Are you able to view emails/contacts etc. normally?
Are you able to work with other Office applications?
Try working in Outlook safe and check if this helps.
Click on Start > Run > Copy and paste the following command line in the open box and press Enter.
Outlook /safe
If you are able to work in Outlook in the safe mode disable the add-ins.
1.On the Tools menu, click Trust Center.
2.In the Trust Center dialog box, select Add-ins.
3.In the Add-ins section of the Trust Center, select Disabled Items in the Manage list and then click Go.
4.To re-enable a disabled item, select the item in the Disabled Items dialog box, and then click Enable.
Click Close, and then click OK.
MeatSim
Yes.
Yes.
I tried both disabling and enabling the add-ins in safe mode and reopening normally. The problem remains.
It seems this is not a unique problem. A Google search found the following screen shot: http://www.experts-exchange.com/Software/Office_Productivity/Groupware/Outlook/Q_23440729.html
and description: http://www.outlookbanter.com/outlook-installation/57439-outlook-options-dialog-box-truncated.html ,
both of which describe my problem. I tried the fix described in the second link and found that I am missing the Tahoma font under Display > Appearance> Advanced > Message Box. I don't know how to get it back. I tried alternately setting it to MS Sans Serif 8 and Arial 8, but neither affected the Outlook dialog box.
J The filter Button is dimmed in the View - Customize Current View dialog. Using Outlook 2007 on Exchange. Using Outlook 3
M Outlook 2007 – Insert Item dialog box shortcomings detected Using Outlook 1
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
R Outlook 2007 - Shared Accounts and Resources without Exchange Server Using Outlook 0
L Outlook 2007 - Macro Re Search Using Outlook 16
D Outlook (Office) 2007 & Windows 10 Pro Using Outlook 6
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
P How to switch back from Outlook 2010 to Outlook 2007? Using Outlook 3
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
A Corrupt tasks in Outlook 2007 Using Outlook 1
Diane Poremsky Outlook 2007 with Office 365? New Slipstick.com Articles 0
D Need Genuine Office or Outlook 2007 Using Outlook 3
