Problems sending emails using Outlook 2010
K
Keith A Wood
Was previously using Oulook in Office 2010 Beta running Windows 7. Have upgraded to Office 2010, and can no longer send emails from Outlook. Can receive emails from ISP (Freeserve) pop3 server, but get the message 'The server responded: 550 5.7.1 Message content' from the SMTP server.
No such problems using Windows Live Mail (that I'm using as back-up), so ISP suggests the problem is with Office 2010. Can you suggest anyhting please? It is driving me mad!
Keith
Ben M. Schorr [MVP]
That particular error usually means you've tripped a content filter somewhere. Do you have antivirus software scanning your outgoing e-mail? Does this happen on every message no matter how trivial the content?
K
Keith A Wood
It happens when i try to set up the new account in Outlook 2010. The pop3 server settings are accepted and the inbox starts to fill up, but then i get that message from the smtp server when the "test" message is sent by the Outlook email account set-up wizard. I cant get beyond that stage. Emails are scanned by AVG - defo inbound, not sure about outbound.
K
Keith A Wood
Have just tried to set up the email account again with the AVG email scanner switched off, and have suffered the same symptoms. ;0(
Ben M. Schorr [MVP]
Freeserve is just your ISP for e-mail, right? You get your bandwidth from somebody else? (Comcast? Qwest? Time Warner? Somebody like that?)
Can you use the SMTP server for your bandwidth provider to send out?
K
Keith A Wood
SORTED!!!!!!!!!!!!! - Switched the AVG email scanner to scan outgoing as well as incoming emails and it worked. YEEEHAAAAA!
C
CactusGirl
HI Ben,
Can you help me, too?
Here's the problem:
Office Version:Office 2010 Operating System:Windows 7Antivirus program:Microsoft Security Essentials
Here is the error I am getting in trying to receive email with Outlook 2010:
Task 'pop.west.cox.net - Receiving' reported error (0x80040154) : 'Unknown Error 0x80040154'
I called my ISP and they said it is a MS problem.
My husband also cannot receive his email; we have two accounts on same computer.
Please help!
Nancy in Tucson
S Problems sending emails. Do you think the account is incorrectly set up? Using Outlook 2
P Problems sending Emails with Outlook 2010 Using Outlook 2
O Problems with sending and receiving emails Using Outlook 2
G The problems are accessing a school web site and sending teachers emails . Using Outlook 1
R Problems sending via POP profile when offline from Exchange Using Outlook 7
C Having problems with taking items out of one folder and sending them into inbox or sending items back to my e-mail address of Email removed for privac Using Outlook 2
M Problem with Outlook 2007 - hotmail not coming in, difficulties sending out, many many other problems Using Outlook 4
R Outlook Sending Problems Using Outlook 1
K problems with sending & receiving email in Outlook 2003 Using Outlook 5
G Problems Sending Publisher Mail Merge Newsletters Through Outlook. Using Outlook 1
G Problems sending email with Outlook 2007 Using Outlook 3
C Outlook Problem - Cannot receive mail, no problems sending mail - only on one computer Using Outlook 2
S Intermittant problems sending mails from Qwest account (Email removed for privacy) - just started 2 days ago Using Outlook 1
U iPhone sending attachment problems Exchange Server Administration 8
