Use edge servers as relay machines for application servers
Themi kotoulas
How can we use Edge servers to receive and send mails for specific internal application servers directly (without the need of Transport servers or LDAP queries to AD users)?
M Re: How to force routing between two internal smtp domains across Two Edge servers Exchange Server Administration 7
M How to force routing between two internal smtp domains across Two Edge servers Exchange Server Administration 3
J Edge + TMG 2010 No email inbound/outbound and cannot telnet to port 25 on TMG Exchange Server Administration 0
J CPA cuts off left edge of printed Calendar. Ex. January the J is cut off. Calendar Printing Assistant 11
S Configure Exchange Edge 2010 on TMG in DMZ Exchange Server Administration 1
S Edge Transport 3rd party mail filter before Exchange 2010 Exchange Server Administration 5
M join internet domain without edge server to the internal DC domain Exchange Server Administration 4
G Ex2010: Edge Sync / SynStatus Inconclusive? Exchange Server Administration 7
S Edge 2010 and Forefront 2010 in DMZ Exchange Server Administration 12
S Edge 2010 and TMG on the same box Exchange Server Administration 1
S Forefront TMG Management Control 2010 on Edge Server. Exchange Server Administration 1
S how to print all emails sent and received via edge in 2010 Exchange Server Administration 13
K Edge to Hub to Exchange 2003 Exchange Server Administration 4
K Edge SyncStatus: Inconclusive Exchange Server Administration 2
T Prerequisites softwares for installing exchange 2010 edge transport server on windows 2008 R2 Exchange Server Administration 1
N Exchnage 2010 Hub Cas Edge Server Recovery Exchange Server Administration 3
K Edge Hub testing Exchange Server Administration 10
J ex2010 edge transport - inbound from internet Exchange Server Administration 7
R Exchange 2010 Edge Transport server not passing emails... Exchange Server Administration 7
A Hub 2010 to Edge 2007 ( Last Error: 421 4.4.2 Connection dropped due to ConnectionReset ) Exchange Server Administration 3
P Exchange 2010 Edge Transport Delays mail Exchange Server Administration 5
H Edge subscription question Exchange Server Administration 1
H Setting up an Edge Transport Server - Exch 2010 Exchange Server Administration 11
D exchange 2010 edge smtp authentication Exchange Server Administration 7
Z Hub Transport and Edge is not working as it should Exchange Server Administration 12
L Plethora of Event ID FAILs on the Edge Transport Exchange Server Administration 4
L Exchange server 2010 edge to hub-transport routing error Exchange Server Administration 9
B Outlook 2010 Outlook not connecting to servers at Comcast. Using Outlook 3
Diane Poremsky Exchange Server and SMTP Servers New Slipstick.com Articles 0
E Does Outlook indexing work across multiple servers? Using Outlook 0
O two profiles send/receive from different servers Using Outlook 1
D Removing multiple Exchange 2007 servers on the same Domain and site Exchange Server Administration 1
J Outlook 2007 with multiple e-mails from different servers Using Outlook 1
B Outlook 2007 New email notification works intermittently after adding Exchange 2010 Servers Exchange Server Administration 1
B Outlook 2010 CAN'T Connect to 2 Different Exchange Servers running Exchange 2010?!?!?!?!?!?! Using Outlook 1
B Outlook 2010 CAN'T Connect to 2 Different Exchange Servers running Exchange 2010?!?!?!?!?!?! Using Outlook 5
T RBAC Error on UM/CAS Servers Exchange Server Administration 2
S Time based access to exchange servers Exchange Server Administration 4
R FQDN of Exchange CAS servers not in SSL cert Exchange Server Administration 2
W Outlook 2010 Duplicate Attachments w/IMAPI Servers Using Outlook 3
S OOF - Terminal/Citrix Servers Exchange Server Administration 5
K Exchange 2010 OWA redirection between 2 CAS Servers Exchange Server Administration 5
X Internal mail flow between two hub transport servers same domain Exchange Server Administration 10
