calendar will not sync between iPhone 3GS v4.1 and Outlook 2007 using iTunes or MobileMe
dotatbeach
After upgrading to v4 on iPhone, my calendar will no longer sync. Contacts are syncing fine. I have tried EVERYTHING on all the forums (MS and Apple). I worked with Apple support and they said it must be an Outlook problem, because when I create a new user with a new calendar in my Outlook 2007, the new calendar syncs to the iPhone. PLEASE HELP! I have been trying to fix this for over a month!
Brian Tillman
Try a new mail profile. Use the Mail applet in Control Panel to create it and add your existing data file to that profile.
dotatbeach
Thanks for the suggestion Brian. When I set up a new mail profile with a new data file, the calendar syncs. As soon as I tell it to use my existing data file, the calendar will not sync.
So, it is still not fixed unfortunately.
P Sync 2013 calendar between 2 devices -Surface 2 and Desktop using Outlook.com Using Outlook.com accounts in Outlook 8
D Sync Calendar Between Domains? Using Outlook 2
A hotmail calendar sync Using Outlook 1
T Outlook 2010 calendar won't sync with Android phone Using Outlook 3
S Sync Outlook 2013 calendar via outlook.com to Android Exchange Server Administration 1
V Any alternative to iCloud for calendar sync to iPhone? Using Outlook 8
F Sync Sharepoint Calendar With Personal Calendar Outlook VBA and Custom Forms 5
T Calendar Entry in Outlook Client but will not sync Exchange Server Administration 1
A sync ol13 contacts and calendar with wp 8.1 Using Outlook.com accounts in Outlook 4
N Sync Contacts and Calendar with 2 Windows 8.1 and 1 iPod Touch Using Outlook 9
F sync outlook + outlook.com, calendar sync only 1way, contact sync 2way OK Using Outlook.com accounts in Outlook 1
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
A Calendar Reminders are Removed with Sync to Outlook.com Using Outlook.com accounts in Outlook 11
C Sync color categories on a Public Calendar across Office 365, PCs, Macs Using Outlook 1
B iPhone Calendar will not sync with Outlook 2013 Using Outlook 0
T Outlook Calendar Sync MY GOAL: see work calendar on home desktop w/o OWA Using Outlook 2
A Problem sync group goole calendar with outlook 2001 Using Outlook 0
K outlook calendar wont sync iphone 4 Using Outlook 1
E Outlook 2013 calendar won't sync with iphone 4s Using Outlook 14
M sync Outlook 2007 calendar with icloud Using Outlook 1
J Outlook Calendar will not sync with Windows Live.com account Using Outlook 9
L Sync Calendar and Contacts Only Using Outlook 1
V Sync Outlook 2003 calendar to iPhone 4 Using Outlook 2
V Sync calendar and contacts using Outlook.com and any LiveID Using Outlook 8
T Calendar sync off by 1 hour - outlook 2010 / icloud 2.1 / ipad Using Outlook 2
V Sync Outlook contacts and calendar to Android phone Using Outlook 3
S Using POP3, Exchange server, and iPhone sync - can't sync to POP3 calendar Exchange Server Administration 0
S Copy Events to Second Calendar or Sync Only "Busy" Events Using Outlook 5
L Cannot sync Calendar to iphone. Cannot export to CSV. Cannot view as Table. Using Outlook 3
C Sync Outlook Calendar and Google Calendar Using Outlook 1
W Unable to sync Outlook contacts and calendar since upgrading from Outlook 2007 to Outlook 2010 Using Outlook 1
M iPad does not Sync with Microsoft Outlook 2010 Contacts, Calendar, Etc. Using Outlook 2
C Sync Outlook calendar & contacts with a DroidX phone Using Outlook 1
M sync calendar and oab to blackberry Exchange Server Administration 5
U How do you get a PC 'Outlook Calendar' to stay in sync with a calendar on my iphone4. Outlook will not even open now. Using Outlook 1
S How can you automatically sync appointments from my personal calendar to a public calendar? Using Outlook 2
R Can my hotmail calendar actually sync with Outlook 2007/2010? Using Outlook 1
D Live Mail Calendar Sync with one calendar Using Outlook 1
H Lost ability to sync MS Outlook 2007 Calendar and Google Calendar Using Outlook 4
H How can I sync outlook web access calendar with outlook? Exchange Server Administration 2
R Outlook 2007 sync issue with other users Calendar Using Outlook 1
S Can you actually sync Outlook contacts & calendar with iPhone? Using Outlook 1
C Old personal PST calendar: want to sync it to outlook.com business email so it syncs to my mobile easily. Using Outlook 2
C MS Office 2007 calendar sync with new iPhone 4 won't work Using Outlook 1
S I can no longer add calendar items on the calendar page, or the contact. Can only do on blackberry and then sync. Used to work just fine! Using Outlook 4
A Exisiting Hotmail calendar events won't sync with Outlook 2010 Using Outlook 7
