Messages will get stuck in my outbox.
P
Persy
After using outlook 2010 for a couple of days messages will get stuck in my outbox. I have to exit and restart outlook for them to go out. I later resolved deleting my email account and creating it again, this works for a couple of days and then experience the problem all over again.
H
Hassan El-Meligy
I suggest removing the account and setting up again.
Regards
N
Niyamath Khan
What type of account is configured in Outlook? E.g. POP/IMAP/Exchange
Do you get any error message while sending emails?
You may open Outlook in safe mode and then try sending emails to check if messages get stuck in Outbox.
Click on Start > Run > Outlook /safe and hit on Enter.
Note: There is space between Outlook and (/) slash.
T SMTP messages stuck in Outbox Using Outlook 0
P Messages stuck in outbox and must be sent again. Using Outlook 1
A Emails stuck in Outbox/new messages can't be found. Using Outlook 2
H Messages are stuck in the OUTBOX ... but won't "send" Using Outlook 5
P Messages get stuck in Outbox and do not get send until Otlook 2010 gets closed and restarted Using Outlook 2
G Outlook 2003 will not send messages. Stuck in outbox, Using Outlook 1
M Messages getting stuck in Outbox Using Outlook 2
T Messages getting stuck in Outbox in Outlook 2007 running under Windows 7 64-bit. Using Outlook 5
F Messages stuck in queue as active Exchange Server Administration 1
B messages are stuck in Out box. Outlook 2007 Using Outlook 4
C SMTP Relay: messages stuck in Queue folder Using Outlook 3
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
O Rules and Alerts for New Messages BEFORE sending Using Outlook 2
Liza Creating a rule in outlook to filter messages Using Outlook 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Save Messages and Attachments to a New Folder New Slipstick.com Articles 0
P AOL messages Outlook VBA and Custom Forms 0
Diane Poremsky Create a custom field for Outlook messages New Slipstick.com Articles 0
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
Diane Poremsky Monitor secondary mailbox folder for new messages New Slipstick.com Articles 0
Diane Poremsky After viewing the Outbox, messages won't send New Slipstick.com Articles 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages New Slipstick.com Articles 0
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
C Changing the name of Outlook Messages saved to a folder Using Outlook 1
S Outlook 2013 doesn't download html messages Using Outlook 0
