Outlook 2007 crashes while inserting network shared path hyperlink into mail body
Y
yuddy7
My outlook will frequently crash when I am inserting a network shared path hyperlink into mail body. I am using Windows 7 Ent x86 & Outlook 2007 (12.0.6539.5000) with SP2 (12.0.6535.5002) and below is the logs from system event viewer.
Log Name: Application
Source: Application Error
Date: 09/21/2010 09:54:02
Event ID: 1000
Task Category: (100)
Level: Error
Keywords: Classic
User: N/A
Computer: SPTVASG51010322.spe.sony.com
Description:
Faulting application name: OUTLOOK.EXE, version: 12.0.6539.5000, time stamp: 0x4c12486d
Faulting module name: SHLWAPI.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdb05
Exception code: 0xc0000005
Fault offset: 0x0001af37
Faulting process id: 0x488
Faulting application start time: 0x01cb5923887f0dca
Faulting application path: C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE
Faulting module path: C:\Windows\system32\SHLWAPI.dll
Report Id: 1b0e30ff-c523-11df-b24e-415645000030
Event Xml:
<Event xmlns=" http://schemas.microsoft.com/win/2004/08/events/event " >
<System>
<Provider Name=" Application Error" />
<EventID Qualifiers=" 0" >1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime=" 2010-09-21T01:54:02.000000000Z" />
<EventRecordID>4331</EventRecordID>
<Channel>Application</Channel>
<Computer>SPTVASG51010322.spe.sony.com</Computer>
<Security />
</System>
<EventData>
<Data>OUTLOOK.EXE</Data>
<Data>12.0.6539.5000</Data>
<Data>4c12486d</Data>
<Data>SHLWAPI.dll</Data>
<Data>6.1.7600.16385</Data>
<Data>4a5bdb05</Data>
<Data>c0000005</Data>
<Data>0001af37</Data>
<Data>488</Data>
<Data>01cb5923887f0dca</Data>
<Data>C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE</Data>
<Data>C:\Windows\system32\SHLWAPI.dll</Data>
<Data>1b0e30ff-c523-11df-b24e-415645000030</Data>
</EventData>
</Event>
Ruchi Bisht
Does it happen only when you insert the network shared path as hyperlink?
Try inserting some other hyperlink link in the body of the email and check if it works fine.
Ruchi Bisht
JenniferDG
I have one user reporting the exact same problem. But it is not happening consistently. When it does happen, it only happens when trying to insert a link to network shared path; it does not happen for links to local files. In addition, when it does happen, it happens in Outlook and Word. After several failed attempts to insert a hyperlink to a file on a network share, it will suddenly work and stay working for several days.
Y
yuddy7
Yes it is only happened while inserting network shared path as hyperlink into mail body, and it works fine as when I am inserting web hyperlinks for several times.
Y
yuddy7
I am just curious whether your user is using Windows 7 as well..?
SCSIAdmin
Was there ever a solution found for this?
I have a user with the exact same issue. PC is win 7 x64, running outlook 2007, both fully patched. The network share that the hyperlink is being taken from is on a fully patched server 2003 R2 x86 box on the the same LAN.
D Outlook 2007 crashes opening email with image links Using Outlook 4
M My outlook 2007 will not open, it just gets stuck and my computer crashes. Using Outlook 1
S Re: Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
T Outlook 2010 crashes when upgraded from Office 2007 Using Outlook 1
P Outlook 2007 Crashes Opening Scheduling Assistant On Some Client PC's Using Outlook 2
L MSOffice 2007 Outlook functions normal, but crashes on specific email's when a reading pane is open. Using Outlook 7
F Outlook 2007 crashes on start up, but not in safe mode Using Outlook 2
T Outlook 2007 crashes moving emails from inbox Using Outlook 1
B Outlook 2007 crashes - Scan PST fails to complete. Using Outlook 2
O Re: OUTLOOK 2007 Crashes on startup Using Outlook 6
F Outlook 2007, crashes when you open sent items Using Outlook 3
L Outlook 2007 crashes when reading pane is open. Using Outlook 10
M Outlook 2007 crashes with BCM BCM (Business Contact Manager) 1
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
