Keyboard types numbers and symbols following two actions: num lock key held and then released and a
C
crossidmag
I have Outlook 2007, I have have been randomly having problems with my keyboard typing numbers (01234...in consecutive order) after I attach a Word Document or when I hit Num Lock and then, release num lock. For the first instance, the numbers would type on the address lines and in the body, and I would usually fix the problem by starting a new email and then i can type again normally on my keyboard. Sometimes, it won't work and the number typing would continue even when starting a new email. I have done virus checks and restarted and the problem just seems to occur randomly. From reading various online solutions sites, I have also done the press the shift button for five seconds fix and sometimes it will fix it, sometimes it won't. I have tried working without the wireless keyboard and it still randomly happens. This has been happening for a few weeks now and although i can sort of do a workaround, it is still very annoying. Can someone share any better solution for this problem?
Thanks,Crossidmag
N
Niranjan I K
Create a new profile for outlook and then check if it resolves your issue. Click here for information on creating Outlook profiles.
U Keyboard Remapper no longer works in Outlook Using Outlook 1
D font control by keyboard Using Outlook 2
I jump to body in open message with one keyboard shortcut? Using Outlook 3
T Column Header Keyboard Shortcut Available? Using Outlook 5
W keyboard shortcut to open Outlook... ? Using Outlook 2
L Outlook 2007 Keyboard Shortcuts Using Outlook 8
R Custom Keyboard Shortcuts for 2010 Using Outlook 3
T Why don't my send button will not send mail from keyboard? Using Outlook 10
W Losing keyboard fuctions Using Outlook 2
N I use the keyboard to delete emails and every so often the focus changes to the reminders window and I delete reminders by mistake Using Outlook 1
T Periodic display of window 'Enter Network Password' that affects keyboard use Using Outlook 1
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
R Outlook 2013 VB rule to auto save attachments with different file types Outlook VBA and Custom Forms 5
H Syncing multiple types of Outlook accounts across various devices/systems. Using Outlook 3
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
T issue/ base and user defined contact types BCM (Business Contact Manager) 2
C Log all types of connection to a mailbox Using Outlook 2
H Better way of writing Macro? Identify multiple types of attachmen Outlook VBA and Custom Forms 5
R How to create a new form showing all types Outlook VBA and Custom Forms 6
R Week numbers for the month in outlook Using Outlook 1
Diane Poremsky Make the Address Book show only e-mail addresses, not fax numbers New Slipstick.com Articles 0
Diane Poremsky Outlook for Mac Version Numbers New Slipstick.com Articles 0
A phone numbers fields in BCM are not correct BCM (Business Contact Manager) 3
N Eliminate the +1 before all numbers Using Outlook 1
wallisellener Contact Phone Numbers layout BCM (Business Contact Manager) 4
I Outlook 2013 - address book showing FAX numbers - How to only show email? Using Outlook 4
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
Commodore Auto-formatting of certain phone numbers Using Outlook 2
A Help with random numbers in autocomplete emails Exchange Server Administration 3
C Outlook 2010 removes + from mobile numbers Using Outlook 3
B Address Book without fax numbers Using Outlook 1
P VBA Macro for formatting multiple phone numbers in outlook contacts Using Outlook 1
E Week numbers in Outlook 2007 Using Outlook 2
X Are there any limits to Address List Recipient Numbers Exchange Server Administration 6
I Inconsistency with Outlook message numbers Using Outlook 3
J pemissions to update titles and phone numbers in the GAL for Exchange 2010 Exchange Server Administration 2
B Outlook 2010 fax numbers showing in email "To" (Address Book) Using Outlook 1
T Need to build contact lists (put name / address / phone & fax numbers / pertinent info about contact & company), make notes (what spoke about Using Outlook 2
J After Applying Exchange 2010 Sp1 Rollup the Build numbers in EMC remain unchanged 14.1.218.15 Exchange Server Administration 1
T Searching for numbers does not always work. Using Outlook 1
S Outlook 2003 contact - not all phone numbers synchronized into Outlook Using Outlook 4
R Address book to show contacts with no email address or fax numbers Outlook VBA and Custom Forms 2
W Contact Forms Phone Numbers Outlook VBA and Custom Forms 1
S How do i group the mails based on the numbers in the subject line Outlook VBA and Custom Forms 1
T sequential project numbers in Business Contact Manager BCM (Business Contact Manager) 2
