[Outlook 2003 VBA] Help to save two attached files in different paths with VBA
sensero
Hi everybody!
Some month ago I started to program Outlook VBA. Currently I am facing one issue I am not been able to find the solution by myself:
I am trying to save two files (attached in the same e-mail)to different disk drive paths. In addition of this issue, what makes this issue complicated is that files has only the mid part of their name always with the same label, changing the beginning and the end of the FileName.
I developed the code pasted below, but the problem is the Index of attachments: files could be saved in the wrong folder, according their attachment index in the e-mail.
Do you have any suggestions to save the file "A" always in the folder "A", and the file "B" always in the folder "B"?
Here you are the code:
Option Explicit
Dim X As Integer
Set objNS = GetNamespace("MAPI")
Set Items = objNS.GetDefaultFolder(olFolderInbox).Items
Application.ActiveExplorer.WindowState = olMaximized
Private Sub Items_ItemAdd(ByVal item As Object)
If TypeOf item Is Outlook.MailItem Then
 Dim Msg8 As Outlook.MailItem
 Set Msg8 = item
If (Msg8.SenderName = "sendername") And (Msg8.Attachments.Count > 0) Then
   Dim olDestFldr8 As Outlook.MAPIFolder
   Dim myAttachments8 As Outlook.Attachments
   Dim Att8 As String
   Const attPath8 As String = "Path"
   Set olDestFldr8 = objNS.Folders("Archivio 2010").Folders("Posta in arrivo")
   ' save attachment
   Set myAttachments8 = item.Attachments
   Dim u As Integer
   For u = 1 To myAttachments8.Count
   Att8 = myAttachments8.item(u).DisplayName
   myAttachments8.item(u).SaveAsFile attPath8 & Att8
   If Mid(Msg8.Attachments.FileName, 7, 9) = "CC+GENIAL" Then
       Kill (attPath8 & Att8)
       Dim Att81 As String
       Att81 = myAttachments8.item(1).DisplayName
       Const attPath81 As String = "Path\A\"
       myAttachments8.item(1).SaveAsFile attPath81 & Att81
   If Mid(Msg8.Attachments.FileName, 7, 9) = "Giornalie" Then
       Dim Att82 As String
       Att82 = myAttachments8.item(2).DisplayName
       Const attPath82 As String = "Path\B\"
       myAttachments8.item(2).SaveAsFile attPath82 & Att82
   Next u
  Msg8.UnRead = False
   Msg8.Move olDestFldr8
Thanks in advance for any help!
P Outlook 2003 - Regra em VBA Outlook VBA and Custom Forms 1
P 'Trusted' VBA code in Outlook 2003? Outlook VBA and Custom Forms 2
M VBA Form how to load in Outlook 2003 Outlook VBA and Custom Forms 4
R Outlook 2003/2007 Rule and Conditions for InBox VBA customization Outlook VBA and Custom Forms 3
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
R Outlook 2003 not working Using Outlook 13
