CAS array in exchange 2003 and exchange 2010 coexsit environment
Sam_33
I just add exchange 2010 CAS and mail server into exchange 2003 organization. everything is work. I would like to install 2nd CAS for HA. I wonder when i finished the setup of client access array between two CAS server, is it MUST configure following items apart from modify all database (Set-MailboxDatabase DB1 - RPCClientAccessServer )
Autodiscover : /Autodiscover
Exchange Control Panel : /ECP
Exchange Active Sync. : /Microsoft-Server-ActiveSync
Offline Address Book: /OAB
Exchange Web Services : /EWS
any impact if no do that ?
Jelly Roll
Sam,
Once you have the CAS array built you can assign it to each Mailbox Database in your site that the array is in. As a side note that if you are using NLB and you also have the Mailbox Server role loaded on the same box you will not be able to use a DAG group.
DAG groups require Windows Failover Clustering which cannot be installed on a box that has NLB or vice a versa.
To answer your main question once you have the CAS configured you can individual configure settings on the virtual directories either through the Exchange Management Console or Shell.
I hope this helps...
Regards....
Sam_33
I wonder if the Mailbox servers existed before the creation of the CAS array, is it necessary to re-configure below virtural directory ?
Jelly Roll
Sam,
If you had a server with the CAS role already loaded just install the second one and configure either a software or hardware load balancer. Once that is done create the CAS array and asign the array to each mailbox database in the site.
You will still see two CAS servers in the EMC to manage so there is no reconfiguring beside the external URL settings to the CAS array name etc.... This can all be done in the EMC.
Hope this helps...
Regards...
Allen Song
There is no necessary to configure the virtual directory based on the CAS array URL. Since autodiscover has the failover feature for the relevant services.
Allen
Allen Song
S What to Use Instead a Hardware-based Load Balancer for an Exchange 2010 CAS Array Exchange Server Administration 21
S Exchange 2010 two datacenters two CAS array Exchange Server Administration 4
Z Active SynC Issue in Exchange 2010 on CAS Array Exchange Server Administration 4
K Outlook client on Exchange 2010 changes cas array name to instance-<guid> Using Outlook 21
P DNS Round Robin on CAS Array Exchange Server Administration 5
B After rebooting one of the cas array servers blackbarry stops working Exchange Server Administration 1
B cas array exchnage 2010 not working properly on vm Exchange Server Administration 5
S One CAS Array for mulitple site Exchange Server Administration 2
S CAS Array - NLB - Can't Ping VIP Exchange Server Administration 4
R accessing owa externally and having a cas array internally Exchange Server Administration 9
K CAS array SSL cert -RPC cas certificate warning Exchange Server Administration 3
R cas array owa is slow Exchange Server Administration 5
S Created CAS Array - Outlook certificate error Exchange Server Administration 2
B Do we need to create a CAS Array for a single server site? Exchange Server Administration 3
M CAS Array Exchange Server Administration 6
R Installing SP1 on Hub/CAS servers in CAS Array Exchange Server Administration 9
R CAS array not working with Outlook Exchange Server Administration 15
B CAS Array article...? Exchange Server Administration 2
C Cas array question Exchange Server Administration 12
T Rename CAS array Exchange Server Administration 4
S CAS array legacy URL Exchange Server Administration 9
S Looking for feedback on this CAS Array testing plan Exchange Server Administration 2
H CAS Array / OWA issues Exchange Server Administration 9
C CAS Array and Outlook Exchange Server Administration 3
C How to assign certificate(s) to an CAS array? Exchange Server Administration 1
C how should i assign an SSL certificate to a CAS array? Exchange Server Administration 2
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
W CAS Array and Autodiscover for Internal and external access Exchange Server Administration 25
C cas array and mapi Exchange Server Administration 1
A NLB, CAS array or OTHER issue? Exchange Server Administration 24
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
L Cas Array failing when assigning using -rpcclientaccessserver Exchange Server Administration 3
C CAS Array : Outlook 2007 profile update Exchange Server Administration 2
R CAS Array Failover Issue Exchange Server Administration 17
A How to delete server members from cas array Exchange Server Administration 6
