MobileMe e-mails marked for deletion in Outlook 2003 but will not actually delete
C
Charlie Mitchell
I've just installed MobileMe on a PC running XP and Outlook 2003. I have everything syncing between my PC, an iPod Touch, and the me.com website. Calendars and contacts work great. E-mail is syncing and new mail is populating in all three places (me.com, Touch, and Outlook) but I can not delete e-mails out of Outlook unless I initiate the delete command from the Touch. If I delete a message from me.com or from Outlook (using either the "X" command or dragging to the trash folder) the message goes gray, gets a strike-through, but will not actually go away. When I delete from me.com the message is deleted there and on the Touch but gray'd out and struck through in Outlook. Same situation when I delete from Outlook. When I delete from the Touch the message does in fact get deleted in all three places. I deleted and re-installed my me.com account in Outlook, set up a test account at me.com and Outlook (suggested by MobileMe support), yet the problem persists. Any thoughts?
Milly Staples - MVP Outlook
Sounds like your e-mail is an IMAP account. You need to use the Edit->Purge command in Outlook to delete the grayed-out messages.
"Charlie Mitchell" wrote in message news:5dc3061d-57aa-4bd7-b047-fc4c62ddd7b4@communitybridge.codeplex.com...
C
Charlie Mitchell
Hi Milly - you nailed it the first try!
Thanks very much for the tip - that took care of the problem.
Charlie
H MobileMe Services Has Stopped Working Using Outlook 27
M How to fix a problem Windows account stopping outlook synch with mobileme? Using Outlook 1
E Will Outlook 2007 support the CALdav protocol like iCal so that it can be synced with MobileMe to re Using Outlook 1
B MobileMe sync does mail and address book, but, does not move contacts from Outlook to MobileMe Using Outlook 1
C outlook 2007 and Mobileme - unable to sync Using Outlook 1
R Syncing Outlook 2010 calendar with Mobileme Using Outlook 1
H Using MobileMe from Apple Using Outlook 1
R mobileme got lost Using Outlook 1
R Can you/how do you/change the default Calender folder; MobileMe syncing issue Using Outlook 6
P Outlook 2010 and MobileMe - Will Not Sync Calendars and Contacts Using Outlook 2
P how to delete multiple modcal calendars caused by iphone and mobileme syncing Using Outlook 3
D calendar will not sync between iPhone 3GS v4.1 and Outlook 2007 using iTunes or MobileMe Using Outlook 3
T mobileme or itunes linking problem Using Outlook 1
L Outlook 2010 Wierd Error message, Mobileme related? Using Outlook 3
D Syncing Mobileme contacts and calendars to Outlook 2010 - receive error code Using Outlook 4
D Can it synch w the calendar on MobileMe ? Using Outlook 1
C Updating Office/Outlook from 2007 to 2010 and wondering if MobileMe Control Panel (ver 1.6) works Using Outlook 2
K can't sync with mobileme Using Outlook 8
T Search for incoming e-mails for a specified time range Using Outlook 1
F Outlook 2016 Junk E-Mails Using Outlook 5
RBLampert Invisible e-mails in Gmail accounts Using Outlook 0
I How to receive mails on behalf of when sent to group mail? Using Outlook 2
R Would creating a new profile cause Outlook to download all the old mails from the server? Using Outlook 1
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
Thiago Manzano Copying E-mails to a folder on HD Using Outlook 1
A Processing Incoming E-mails with Macros New Slipstick.com Articles 0
P Send mails by Gmail not shown in outlook Using Outlook 5
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
Karsten V invites from outside company arrives as regular mails Using Outlook 2
A Encrypting mails depending from the address Outlook VBA and Custom Forms 0
Yusufbodrum Highlighting selected mails in any folder Using Outlook 2
C Linking e-mails BCM (Business Contact Manager) 1
S Mails getting downloaded multiple times Using Outlook 1
K Macro doesn't recognize local mails from colleagues Outlook VBA and Custom Forms 2
I Delete e-mails from server Using Outlook 2
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T Cannot get pop3 mails to my Android and Outlook Exchange Server Administration 1
A 1 folder to see all new mails Using Outlook 1
A Contacts missing in imported mails Using Outlook 1
L Selected Contacts For E-Mails Using Outlook 19
L Move E-Mails to Another Folder Using Outlook 66
