Re: Outlook 2007 delete rules will not work
  • Thread starter Ben M. Schorr [MVP]
  • Start date
Ben M. Schorr [MVP]
Are you sure that there any message that meet that criteria? As a test you could change the action from " Permanently Delete" to " Display a Specific Message" or " Play a Sound" and see if that rule triggers.
I suspect that the messages just aren't really meeting the criteria to fire the rules.
Out of curiousity, why don't you want to let the Junk E-mail filter do its job? In my experience if it's kept updated and properly configured it does pretty well.
Tom Herink
When I can see that a message has " .ru/" in it, and I run the rule, " Apply this rule after the message arrives with .ru/ in the body permanently delete it and stop processing more rules" , and nothing happens, then isn't it reasonable to conclude that the rule is not working?
I do not like using the spam rules because I still have to look at the spam that accumulates in the Junk Mail folder and also look for false positives that should not have been sent to the Junk Mail folder. Also I don't want to have it permanently delete suspected spam, because it might delete valid e-mails. But since there is no solution to Outlook 2007's non-functioning rules I will turn on " High: Most junk e-mail is caught ..." .
Thanks for your help.
Ben M. Schorr [MVP]
It may be that there is a disconnect between what the rule is seeing and what you are seeing. Do you need the " /" at the end of the string of text? What if you just have it check for " .ru" ? It could be that slash is causing an issue. Could you perhaps look for different criteria? Body text searches against spam are notoriously flakey because, espeically in HTML mail, spammers are so devious about camouflaging what the ACTUAL underlying text is. It may look like " .ru/" to you but that might not be what the underlying source (which Outlook looks at) is.
L Outlook 2007 Delete Email Addresses Using Outlook 19
L Outlook 2007 Delete and Paste Between Fields Using Outlook 25
S can't delete duplicate account under Outlook 2007 (Win 7) Using Outlook 16
K Can't Delete Mail from Deleted Mail Folder, Outlook 2007, Windows XP Using Outlook 3
V Incoming message too large to receive in Outlook 2007 - how to delete it so both send/receive again Using Outlook 2
L How can I delete stationery from Actions, New Mail Message Using in outlook 2007? Using Outlook 6
M Cannot delete an e-mail with a large attachment from the OUTLOOK 2007 outbox. Using Outlook 1
T 'Reviewer' access to my task list in Outlook 2007 is allowing the delegate to delete individual tasks Using Outlook 1
C Outlook 2007 locks up every time I delete calendar reminder Using Outlook 1
S Cannot Delete Folders in Outlook 2007 Using Outlook 4
G How do I delete outlook 2010 trial so my outlook 2007 works without errors Using Outlook 2
S Looking for client-side method (Outlook 2007/Exchange 2007) for users to delete Outlook VBA and Custom Forms 2
Diane Poremsky Manually create a POP3 account in Outlook 2007 New Slipstick.com Articles 0
