email stuck in outbox and sends repeatedly
spydermat
I have Outlook 2010 on my PC running XP. When ever I send a message with an attachment it stays in the outbox and sends repeatedly. It even maxed out my bigpond account ! I tested sending it to my hotmail account and it sent it 22 times before i stopped it and manually deleted it. I have changed mail profiles so it sends sent mail to another account but nothing works. I never had this problem with 2007 Outlook ! It doesnt seem to matter on the size of the attachment. I have tried with 1mb, 2mb and 4 mb. All the same results.
Ben M. Schorr [MVP]
What anti-virus software are you using? If you have it scanning your outgoing e-mail, turn that off.
spydermat
I AM RUNNING TREND MICRO. I HAVE TURNED OFF OUTGOING EMAIL SCAN.
N
Niyamath Khan
What type of account is configured in Outlook? POP/IMAP/Exchange
Try to send email with attachment through Outlook in Windowsclean boot mode to check if it helps.
Note: Ensure to restart computer to normal mode once troubleshooting is completed.
Ben M. Schorr [MVP]
How often do you have it set to automatically send/receive mail? You might try starting Outlook with the /NOPOLLMAIL switch and initiate a single mail transfer with F9, then wait for that to complete before send/receiving again and see if that helps. See if this helps - http://www.officeforlawyers.com/outlook/tsol.htm#CLS
N
Niyamath Khan
Did you try sending email with attachment through Outlook in Windowsclean boot mode to check if it helps?
spydermat
I checked the send/recieve and its on 30 minutes.
I had this message come up:
sending reported error 0x8004210B. The operation timed out waiting for a response from the sending server.
But i still recieved it 14 times.
P
Pollardie
How is internet connection? Wireless or Wired?
If it is through router then try connecting directly and check.
Or
Start computer in safe mode and then try to send email and check what happens
spydermat
I have rung Dell and they told me it was a Bigpond problem. So I rang Bigpond and they told me they currently have no support for Outllook 2010. I changed back to outlook 2007 and everything seems to be fine.
I think someone needs to make a phone call to Outlook (bigpond!!) and sort there product out. Get with the program..
P OL 2007 XP email stuck in outbox Using Outlook 3
D Email stuck in Outbox Using Outlook 3
G Email stuck in Outbox - Office 2013 Using Outlook 5
N Email Stuck in Outbox - Cached Mode - Roaming Profile Using Outlook 2
D Windows 7 / Outlook 2007 - email gets stuck in Outbox Using Outlook 2
S outbox is stuck sending an email. Using Outlook 1
A An email is stuck in my outbox Using Outlook 2
M Distribution lists not working, outlook will not open properly and email stuck in outbox. Using Outlook 3
C Email stuck on outbox and will not send. Using Outlook 3
D Email message gets stuck in Outlook 2007 Outbox Using Outlook 5
C Email stuck in Outbox and tries to keep sending. Using Outlook 1
S I am not able to delete an email stuck in my outbox. All of the various delete actions have been tried without success. Using Outlook 2
J email is stuck in outbox Using Outlook 2
S Having trouble with email stuck in outbox Using Outlook 1
C Deleting stuck email from Outlook 2007 outbox Using Outlook 1
C Email stuck on outbox Using Outlook 1
J video email stuck in outbox Using Outlook 1
C Tried to send an email with attachments that were too large and not it is 'stuck' in my outbox. Using Outlook 1
W email stuck in outbox Using Outlook 6
H Email stuck in Outbox and cannot delete it. Using Outlook 3
T how do I delete email from outbox...they are stuck Using Outlook 1
M deleting an unsent email that is stuck in the outbox Using Outlook 0
P Email is getting stuck on outbox in outlook 2010. Using Outlook 1
3 email with photos is stuck in outbox Using Outlook 1
M large emails stuck in outbox, receiver keeps getting the same email Using Outlook 1
K Outlook 2007: email sporadically stuck in outbox Using Outlook 4
M I have an email with photo attachment stuck in Outbox. When I try to delete it says, "THis item coul Using Outlook 2
R Outlook 2003 Email stuck in Outbox when using a non-admin ID Using Outlook 6
T Add-in problem: First email in outbox gets stuck Outlook VBA and Custom Forms 7
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
A email stuck on send Using Outlook 3
M Outlook 2003, email stuck in send mode, cannot delete Using Outlook 1
S 35MB email stuck in Outlook 2003 Using Outlook 4
C I have an email stuck in my outlook out box and the system will not let me delete it. How do I remove it? Using Outlook 1
D Sending email from Office 365 alias in Outlook Using Outlook 4
S Macro or plug-in to see if specific person was included in this email Outlook VBA and Custom Forms 2
S Body text of Email from invite date/time Outlook VBA and Custom Forms 8
R Outlook 2010 How do you export 2 email Accounts' 2010 Inbox Files to new computer (2019)? Using Outlook 1
L Outlook saved email templates Using Outlook 1
