Outlook Pane Splitter
  • Thread starter Hassan El-Meligy, MSc
  • Start date
H
The Outlook Pane Splitter is very thin and very hard to move
Is there a way to make the splitter thiker and movable
Ben M. Schorr [MVP]
The lines are not changeable, sorry. You might be able to use the Magnifier (Start | Programs | Accessories | Ease of Access) to see/manipulate it a bit better.
H
Thanks Ben,
I will keep searching and let you know if find any issue related to the splitter
The issue is that I feel that the prorammer have a parameter somewhere where you can change the thikness of the splitter
Thanks again
Ben M. Schorr [MVP]
Good luck with that. There's no such parameter, that a user could change, that I've ever seen and I've been involved with Outlook since 1996.
H
Hi Ben, My problem is that I have been in programming for long time and I use to hide these parameters somewhere such that I would be able to change some of the configuration of that kind. I just have some hope that there is one. Otherwise if there is a hotfix to make the splitter thinker such that the mouse can see it. Mybe the folks at MS would do that and place it in an update Thanks and let me know if you find anything Best Regrards
