Cas array question
  • Thread starter Cas array question
  • Start date
C
Cas array question
I have created a NLB CAS array to help with RPC latency issues. It is working well and I can see clients using the CAS array, but when I created the CAS array in the default site it included my primary HUB T/CAS server as well, this is ok, but the HUB/CAS server is not running NLB only the two CAS array servers. This of course means the HUB/CAS server is not load balancing the majority of the client connections. Is there a way to set an order or weight he auto discover to use the HUB/CAS server as a last resort? I know I could probably just add the HUB/CAS to the NLB cluster, but it would require quite a bit of redesign. Here is a brief overview of my installation. My only goal here is to have the outlook clients connect to the CAS to keep that load off the primary Hub/Transport server.
EXHUB-Hub transport/Outlook anywhere/CAS
CAS1- NLB cluster/CAS ONLY/Outlook anywhere disabled.
CAS2- NLB cluster/CAS ONLY/Outlook anywhere disabled.
EXMB1-Mailbox role
EXMB2-Mailbox role
EXMB3-Mailbox role
EXMB4-Mailbox role
Any insight is appeciated.
Chad
Busbar [MVP]
if the CAS servers are not in NLB then creating the array is currently useless, clients will still connect now to the CAS server name as if you didn't the CAS array, if you create new mailbox database it will use the CAS array FQDN as RPCCLEINTACCESSSERVER.
so the FQDN you created now just points to a single server and thus the failover process is manual.
have you got it.
Regards, Mahmoud Magdy Watch Arabic Level 300 Videos about Exchange 2010 here: http://vimeo.com/user3271816 Read pretty advanced Exchange stuff I post here: http://www.enowconsulting.com/ese/blog.asp, follow my blog: http://autodiscover.wordpress.com , corp blog: http://ingazat.wordpress.com, Follow me on twitter http://www.twitter.com/_busbar and if you Liked my post please mark it as helpful and accept it as an answer
Busbar [MVP]
the CAS array FQDN is just a name that points to IP that should point to a VIP that load balance your CAS Traffic, when you create the CAS array you supply its FQDN.
old mailbox databased will not use the CAS array so you must change it manually, so if you don't use NLB it is just another FQDN that is same as CAS server FQDN so it will not load balance the traffic nor provide HA. the CAS array itself do nothing.
Michel de Rooij
You can't do anything with order or preference, especially not with servers which aren't part of the NLB array. Few things to keep in mind:
* Create a CAS array to simplify administration of the RPC/MAPI clients. Configure this using the RPCClientAccessServer (see http://eightwone.com/2010/01/27/exchange-2010s-cas-arrays-nlb/ )
* You can only point RPCClientAccessServer to 1 server or to a CAS Array / NLB FQDN
* NLB distributes clients dynamically depending on things like preference, affinity, current load, etc. An even (50/50) distribution of clients is rare.
* RPC/MAPI traffic is independent of OWA/ActiveSync/IMAP/.. clients
* Why not remove the CAS role from the EXHUB?
* You have a redundant setup (I assume, multiple Mailbox servers), but only 1 Hub Transport server?
Michel de Rooij,
MCITP Ent.Msg 2007+2010| MCTS W2008, Ex2007+2010 Conf, OCS2007 Conf | MCSE+Msg2k3 | MCSE+Inet2k3 | Prince2 Fnd | ITIL
I blog on http://eightwone.wordpress.com/ and tweet on http://twitter.com/mderooij
Brian Day MCITP
No it didn't. When you use Get-ClientAccessArray it'll show you the *possible* candidates for inclusion in the WNLB or Hardware LB, it doesn't actually mean it is doing anything with them. :) It is up to you to actually put the nodes you want into the load balancing mechanism of your choice.Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
C
Cas array question
Yes I only have one transport server at this time. Based my Organization size we should be ok with one. What i experienced when all of my clients start hitting the HUB/Transport/Server is high rpc latency and slow outlook connections. I had a premier case open, and Microsoft stated the answer was to turn on cache mode. After doing this it seemed to fix the issues. But i wanted to create the CAS cluster to ease that load even further on the main CAS/HUB/Transport server, and for the most part the CAS NLB is doing its job I see 150 clients per CAS array server. The problem with removing the CAS role from the main server is that everything is working, and my user base has absolutely 0 patience or tolerance for downtime.
Busbar [MVP]
if you want to use NLB then you should configure NLB either using WNLB or HLB, the CAS array itself doesn't provide LBRegards, Mahmoud Magdy Watch Arabic Level 300 Videos about Exchange 2010 here: http://vimeo.com/user3271816 Read pretty advanced Exchange stuff I post here: http://www.enowconsulting.com/ese/blog.asp, follow my blog: http://autodiscover.wordpress.com , corp blog: http://ingazat.wordpress.com, Follow me on twitter http://www.twitter.com/_busbar and if you Liked my post please mark it as helpful and accept it as an answer
Scott Feltmann
Hi Cas Array question,
Only the servers that are being load balanced will be in the array.
The problem you may be seeing is that the CASArray is not defined in the RPCCLIENTACCESSSERVER property under the get-mailboxdatabase command.
If you do a " Get-Mailboxdatabase | FL Name,RPCLIENTACCESSSERVER" You will get a list of all the databases and their connection points. You may need to update those databases with the wrong connection point by doing a " Set-Mailboxdatabase -Identify databasename -RPCCLIIENTACCESSSERVER casarray.fqdn.com
For more information on the new RPC features check here:
Uncovering the new RPC Client Access Service in Exchange 2010 (Part 1)
http://www.msexchange.org/articles_tutorials/exchange-server-2007/planning-architecture/uncovering-new-rpc-client-access-service-exchange-2010-part1.html
SF - MCITP:EMA, MCTS: Exchange 2010, Exchange 2007, MOSS 2007, OCS 2007 -- http://www.scottfeltmann.com
James-Luo
I assume you have pointed all mailboxes databases to the CAS Array, as you said “I see 150 clients per CAS array server”. Since main server isn"t in the NLB, and the mailbox databases haven"t pointed to it, I think it won"t handle the client request. So, removing CAS role on the main servers shouldn"t be a problem as long as all the services is pointing to the CAS Array
But I"m confused about your words below. As you said, you want to ease the load, why you try to remove the CAS role rather than add the main server into the NLB? Isn"t that the way to ease the load? Please correct me if I have misunderstood the question
Quote: “But i wanted to create the CAS cluster to ease that load even further on the main CAS/HUB/Transport server … The problem with removing the CAS role from the main server is that everything is working, and my user base has absolutely 0 patience or tolerance for downtime”
James Luo
C
Cas array question
James
I have pointed all of the mailboxes to the array, but for some reason when i created the CAS array it automaticly added all of my cas servers to it.I think it was supposed to ,but Mr. Day above disagrees. The concern with removing the CAS roll on the Main CAS/HUB is that OWA and Active Sync and BES and all of that jazz are working, and removing that role will break that. I never intended to have the Main/hub server in the CAS array its was an unindended negative result.
Busbar [MVP]
the CAS array is one per AD site and will include all of the CAS servers. if you have other CAS servers to server the users then service will not step when removing the CAS Role.
James-Luo
Mr. Day isn"t disagree what you saw. What you saw is the expected behavior. The array object is logical, and will contain all the CAS in an AD site, but has no impact on traffic or load balancing, which is the job of the admin to control by using NLB
About removal of the CAS role, please make sure that all the CAS related services are provided by your other two CAS servers, as you said, like OWA, ActiveSync and BES. Then, you can safely remove the CAS role
James Luo
P DNS Round Robin on CAS Array Exchange Server Administration 5
B After rebooting one of the cas array servers blackbarry stops working Exchange Server Administration 1
B cas array exchnage 2010 not working properly on vm Exchange Server Administration 5
S One CAS Array for mulitple site Exchange Server Administration 2
S CAS Array - NLB - Can't Ping VIP Exchange Server Administration 4
R accessing owa externally and having a cas array internally Exchange Server Administration 9
K CAS array SSL cert -RPC cas certificate warning Exchange Server Administration 3
S What to Use Instead a Hardware-based Load Balancer for an Exchange 2010 CAS Array Exchange Server Administration 21
R cas array owa is slow Exchange Server Administration 5
S Created CAS Array - Outlook certificate error Exchange Server Administration 2
S Exchange 2010 two datacenters two CAS array Exchange Server Administration 4
B Do we need to create a CAS Array for a single server site? Exchange Server Administration 3
M CAS Array Exchange Server Administration 6
R Installing SP1 on Hub/CAS servers in CAS Array Exchange Server Administration 9
R CAS array not working with Outlook Exchange Server Administration 15
B CAS Array article...? Exchange Server Administration 2
T Rename CAS array Exchange Server Administration 4
S CAS array legacy URL Exchange Server Administration 9
S CAS array in exchange 2003 and exchange 2010 coexsit environment Exchange Server Administration 4
S Looking for feedback on this CAS Array testing plan Exchange Server Administration 2
H CAS Array / OWA issues Exchange Server Administration 9
C CAS Array and Outlook Exchange Server Administration 3
C How to assign certificate(s) to an CAS array? Exchange Server Administration 1
C how should i assign an SSL certificate to a CAS array? Exchange Server Administration 2
Z Active SynC Issue in Exchange 2010 on CAS Array Exchange Server Administration 4
T CAS Array/RPCClientAccessServer and Outlook profile experiences Exchange Server Administration 8
W CAS Array and Autodiscover for Internal and external access Exchange Server Administration 25
C cas array and mapi Exchange Server Administration 1
A NLB, CAS array or OTHER issue? Exchange Server Administration 24
C Reboot a CAS array member causes Outlook 2010 clients to prompt for credentials. Using Outlook 5
L Cas Array failing when assigning using -rpcclientaccessserver Exchange Server Administration 3
C CAS Array : Outlook 2007 profile update Exchange Server Administration 2
R CAS Array Failover Issue Exchange Server Administration 17
K Outlook client on Exchange 2010 changes cas array name to instance-<guid> Using Outlook 21
A How to delete server members from cas array Exchange Server Administration 6
