The filter Button is dimmed in the View - Customize Current View dialog. Using Outlook 2007 on Exchange.
jbreaud
I previously created a filter for a custom view. The Filter button is dimmed when I attept to access or change the filter.
E
Ezil Vinoth
Rename the Views.dat file from the following locations:
C:\Documents and Settings\<username>\Application Data\Microsoft\Outlook
Restart Outlook and verify the status. If the issue continues, create a new Outlook profile then then setup the email account in it.
Ensure Office 2003 service pack 3is installed.
Roady [MVP]
Outlook 2003 doesn't store its views in a views.dat file but in the mailbox itself.
Roady [MVP]
For which view type and folder are you trying to create a filter?
Try resetting the view of that folder via;
View-> Arrange By-> Custom-> Reset Current View...
If that doesn't work, start Outlook with the cleanviews switch;
Start-> Run; outlook.exe /cleanviews
M Greyed out Filter-EMail button Using Outlook 15
B Task Filter Not Working When I add too many criteria Using Outlook 0
M Filter Conversations - Filter Out Single Emails Outlook VBA and Custom Forms 3
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
G How to filter by the format of an email address Using Outlook 6
S Mail filter recieved before the last 2 working days Using Outlook 1
Liza Creating a rule in outlook to filter messages Using Outlook 0
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
Diane Poremsky Filter and Save Contacts to a CSV File New Slipstick.com Articles 0
Fozzie Bear HomeTab Email filter "Greyed Out" in Outlook 2013 Exchange Server Administration 3
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
J Outlook VBA for Email Filter Outlook VBA and Custom Forms 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
M Filter today's mail Using Outlook 2
J Task Filter for Status OR One Month Using Outlook 4
R Filter Views by Category Using Outlook 2
D Junk Mail filter Using Outlook 1
S Filter by accounts but communicate to all linked contacts BCM (Business Contact Manager) 1
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
J Outlook Contacts: How to filter contact phone numbers from a cti request Using Outlook 1
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
D How Would I Write This Filter? Using Outlook 3
N Filter end date works differently in OL'07/OL'10 vs OL'03? Hello?! Using Outlook 12
williamlambton Filter which removes Display Names from incoming emails. Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
L Need a good email filter Using Outlook 2
D How to manage and configure antispam updates for Hub Transport antispam filter agents at "filesystem Exchange Server Administration 1
S Edge Transport 3rd party mail filter before Exchange 2010 Exchange Server Administration 5
G OWA premium not working for new mailboxes - Corrupt restriction filter data Using Outlook 4
F Office 2010 Mail merge into Work 2010 using a specific Outlook catagory filter. Using Outlook 2
M Junk Mail filter not working for all blocked addresses Using Outlook 2
R Ignore Conversation - does it just filter on subject line? Using Outlook 1
N Outlook 2010, Categories, best way to filter contacts? Using Outlook 5
M Rules will not filter my emails... Using Outlook 1
T using a filter to forward emails from a different account than the one that received them Using Outlook 5
G Outlook Junk Filter Settings Using Outlook 1
M Can one teach the Junk filter to check for entire words, not substrings? Using Outlook 1
F Inbox Count with Filter Using Outlook 1
D Create Receive Filter Exchange Server Administration 2
M How to disable Outlook 2007's junk mail filter? Using Outlook 10
E Gmail IMAP not working since installing junk mail filter update Using Outlook 1
M How to disable OL2007's junk mail filter? Using Outlook 2
