CAS array not working with Outlook
Raul2011
I am having trouble using CASarray FQDN Outlook.domain.com
Basically I have 2 Exchange servers Hub/CAS/Mailbox installed which are part of one DAG.
I have created CAS array and also created A record for outlook.domain.com into DNS. I am planning to use hardware LB to for CAS array.
Although at this moment, my focus is to just get CAS array URL working for Outlook 2007 configuration.
When I create Outlook profile with CAS1.domain.com , it works fine. Outlook and exchange RPC encryption is available.
But when I am using Casarray FQDN which is outlook.domain.com it is not checking the user name and it stucks for few mins and gives me below error.
The action could not be completed. The connection to the Microsoft Exchange Server is unavailable. Outlook must be online or connected to complete this action" .
I have tried recreating AutoDiscover virtual directory in IIS on both CAS servers. Added Autodiscover A record in DNS.
I have added Set-ClientAccessServer -Identity CASServer -AutoDiscoverServiceInternalUri https://outlook.domain.com/Autodiscover/Autodiscover.xml
Everything is in same subnet. no networking issue. DAG is up and running.
I have also researched a lot to fix this. But I am not finding any solution. I appreciate if anyone can help me troubelshoot this.
Thanks in adavance.
TWHarrington
In 2010, every database has a parameter called RPCClientAccessServer.
This can be viewed by running: Get-MailboxDatabase <DB name> | fl RpcClientAccessserver
If you want the database to use the CAS Array name for RPC access, you will need to change that parameter:
Set-MailboxDatabase <name of DB> -RpcClientAccessServer &ldquo;CASArrayName&rdquo;
One other side note, the autodiscover URL should not be mapped to the CAS Array Name, this is usually mapped to autodiscover.domain.com/autodiscover/autodiscover.xml, with a DNS A record of autodiscover.domain.com pointing to the VIP of your CAS servers.
Good Reference:
http://www.msexchange.org/articles_tutorials/exchange-server-2007/planning-architecture/uncovering-new-rpc-client-access-service-exchange-2010-part1.html
Raul2011
Thanks for your prompt reply. I have stamped databases to use CAS array and verified it. I have ran below command.
New-ClientAccessArray " Outlook" -Fqdn " Outlook.domain.com" Site " Site1"
Get-MailboxDatabase | Set-MailboxDatabase -RPCClientAccessServer " outlook.domain.com"
Get-Mailboxdatabase | FL Name,RPCLIENTACCESSSERVER
DatabaseName Outlook.domain.com
I am confused here when you stated that......
One other side note, the autodiscover URL should not be mapped to the CAS Array Name, this is usually mapped to autodiscover.domain.com/autodiscover/autodiscover.xml, with a DNS A record of autodiscover.domain.com pointing to the VIP of your CAS servers....
I have below configuration for CAS array
CAS array name: Outlook
FQDN: Outlook.domain.com
IP : 192.168.1.100 Outlook.domain.com (A record in DNS)
IP : 192.168.1.100 Autodiscover.domain.com (A record in DNS)
Site: Site 1
Excahgne servers: Ex1 , Ex2
My question: Are you trying to say that CAS array name should not be " Outlook" in this case? Also correct me anything I need to change.
I greatly appreciate your time. Thank you.
TWHarrington
It can be confusing. The CAS Array is really only meant for RPC Client access only and should have its own unique name (not the same as your web services). The CAS Array A record usually ends up pointing to the same load balanced VIP as the OWA/autodiscover names. So you should have three FQDN/A records pointing to your HLB VIP: outlook.domain.com, autodiscover.domain.com, and owa.domain.com. Outlook clients will use the outlook.domain.com name to connect Outlook to Exchange. If you enable Outlook Anywhere (OA), this usually points to the OWA FQDN. You will want to make sure the OA does not use the same name as the CAS Array.
Raul2011
Hi Tim,
I have removed complete CAS array and restamped database to use CAS1.domain.com Databases should now use CAS FQDN for autodiscover.
I saw your blog about CAS server troubleshooting. I ran test-outlookconnectivity -Protocol http and its failing with below error now.
Autodiscover webrequest failure
The cmdlet fails to find all the server information through pinging service providers or other topology discovery insid
e the domain. The cmdlet cannot continue. TopologyDiscoverMode = 'UseAutodiscover, UseAddressbook'.
+ CategoryInfo : OperationStopped: (Microsoft.Excha...onnectivityTask:TestOutlookConnectivityTask) [Test-
OutlookConnectivity], TopologyDiscoverException
+ FullyQualifiedErrorId : 2395F7EB,Microsoft.Exchange.Monitoring.TestOutlookConnectivityTask
I am able to login to owa. But owa site is taking to long to respond. Also when I ran test-owaconnectivity , it failed with time out.
Any clue on how to deal with this?
Raul
Rick2011
I have deleted CAS array and recreated it and also recreated autodiscover Virtual directory. Hardware LB is now configured. Below is the configuration
Cas Array = Casarray1 = IP 192.168.1.100 = A record in DNS
Autodiscover = 192.168.1.100 = A record in DNS
CAS FQDN = Mail.domain.com = 192.168.1.100 = A record in DNS
Hardware load balancer IP is 192.168.1.100 same and load balancing on 2 CAS servers in same subnet.
Database is stamped to use CASarry FQDN mail.domain.com
After all config I have restarted CAS severs. Created new account in Exchange 2010.
Tried to configure Outlook 2007 , Same error.
Some how outlook profiles are not taking mail.domain.com and not checking user name also. I am able to configure profiles with CAS servers FQDN but not with CASarrray's FQDN
Any suggesions will be apprecaited. Thanks.
Raul
E
ExTech2010
Try to point CAS Array to one servers in DAG, and see what's happening. Just in case flush DNS, and try to ping CAS Array before connecting Outlook, to be sure it is pointing there where you want.
James-Luo
Please check if there"s any related event in the application log on the CAS server after reproduce the issue
Please run the following cmdlets to test the outlook connectivity and CAS Array:
Test-OutlookConnectivity -Protocol:TCP -Identity contoso.com\jamesluo -MailboxCredential:(get-credential contoso\jamesluo) -verbose | Fl C:\Test1.txt
Test-OutlookConnectivity -RpcTestType:Array -Identity contoso.com\jamesluo -MailboxCredential:(get-credential contoso\jamesluo) -verbose | Fl C:\Test1.txt
Please check RPC Client Access Protocol Logging on the CAS server, which is enabled by default
Notes: The path is " %ExchangeInstallDir%\Logging\RPC Client Access\"
James Luo
Rrr2011
I am able to ping CASarray and autodiscover dns record. I flushed DNS in client machine, updated Outlook 2007 SP2. Still same error.
I have ran commands suggested and it came back error with RPC server not available. Could not establish trust relationship for the SSL/TLS secure channel and remote certificate is not installed.
I am having this setup in lab and dont have direct internet connectivity. Below are the verbose outputs requested.
[PS] C:\Windows\system32>Test-OutlookConnectivity -RpcTestType:Array -Identity contoso.com\rick -MailboxCredent
al:(get-credential contoso.com\rick) -verbose | Fl C:\Test2.txt
VERBOSE: [17:53:44.067 GMT] Test-OutlookConnectivity : Active Directory session settings for 'Test-OutlookConnectivity'
are: View Entire Forest: 'False', Default Scope: 'contoso.com', Configuration Domain Controller:
'DC1.contoso.com', Preferred Global Catalog: 'DC.contoso.com', Preferred Domain Controllers: '{
DC.contoso.com }'
VERBOSE: [17:53:44.067 GMT] Test-OutlookConnectivity : Runspace context: Executing user: contoso.com/User
Accounts/Domain Admins/Joshi, Rahul, Executing user organization: , Current organization: , RBAC-enabled: Enabled.
VERBOSE: [17:53:44.067 GMT] Test-OutlookConnectivity : Beginning processing &
VERBOSE: [17:53:44.067 GMT] Test-OutlookConnectivity : Instantiating handler with index 0 for cmdlet extension agent
" Admin Audit Log Agent" .
VERBOSE: [17:53:44.067 GMT] Test-OutlookConnectivity : Current ScopeSet is: { Recipient Read Scope: {{, }}, Recipient
Write Scopes: {{, }}, Configuration Read Scope: {{, }}, Configuration Write Scope(s): {{, }, }, Exclusive Recipient
Scope(s): {}, Exclusive Configuration Scope(s): {} }
VERBOSE: Target Mailbox = 'contoso.com\rick'
VERBOSE: [17:53:44.083 GMT] Test-OutlookConnectivity : Resolved current organization: .
VERBOSE: [17:53:44.083 GMT] Test-OutlookConnectivity : Based on RpcTestType, the cmdlet needs to dynamically look up the endpoint that uses this server as reference point.
VERBOSE: [17:53:44.083 GMT] Test-OutlookConnectivity : Target site ='contoso.com/Configuration/Sites/Newyork
VERBOSE: [17:53:44.099 GMT] Test-OutlookConnectivity : Searching for a Client Access array in target site. Site = 'contoso.com/Configuration/Sites/Newyork.
VERBOSE: [17:53:44.099 GMT] Test-OutlookConnectivity : Client Access array FQDN = 'mail.contoso.com'
VERBOSE: [17:53:44.099 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:44.114 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:44.114 GMT] Test-OutlookConnectivity : Using connection parameters : 'contoso.com\rick:
Rfri/TCP-IP, [mail.contoso.com/Negotiate]'
VERBOSE: [17:53:44.114 GMT] Test-OutlookConnectivity : Mailbox = 'contoso.com\rick', Owner = '/O=Contoso/OU=NY/cn=Recipients/cn=rick'
VERBOSE: [17:53:44.114 GMT] Test-OutlookConnectivity : Address Book Operation = 'GetNewDSA', Input = 'userLegacyDN',
Input Value = '/O=Contoso/OU=NY/cn=Recipients/cn=rick'
VERBOSE: [17:53:49.192 GMT] Test-OutlookConnectivity : Microsoft.Exchange.Rpc.ServerUnavailableException: Error 0x6ba
(The RPC server is unavailable) from cli_RfrGetNewDSA
EEInfo: ComputerName: n/a
EEInfo: ProcessID: 5688
EEInfo: Generation Time: 2010-10-08 17:53:49.192
EEInfo: Generating component: 2
EEInfo: Status: 0x000006BA
EEInfo: Detection location: 1710
EEInfo: Flags: 0
EEInfo: NumberOfParameters: 1
EEInfo: prm[0]: Long val: 0 (0x00000000)
at ThrowRpcException(Int32 rpcStatus, String message)
at Microsoft.Exchange.Rpc.RpcClientBase.ThrowRpcExceptionWithEEInfo(Int32 rpcStatus, String routineName)
at Microsoft.Exchange.Rpc.Rfri.RfriRpcClient.GetNewDSA(String userDN, String& server)
at Microsoft.Exchange.Monitoring.RfriClientWrapper.<>c__DisplayClass7.<GetNewDSA>b__6()
at Microsoft.Exchange.Monitoring.OutlookConnectivityContext.RpcExceptionWrapper(Func`1 protectedCall)
VERBOSE: [17:53:49.192 GMT] Test-OutlookConnectivity : AddressBook operation failed. Operation = 'GetReferral', Error
= 'The Address Book Referral operation failed. Operation = '<GetNewDSA>b__6', returnValue = '1722', server =
'CAS1.contoso.com', user = '/O=Contoso/OU=NY/cn=Recipients/cn=rick', .'
VERBOSE: [17:53:49.208 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:49.224 GMT] Test-OutlookConnectivity : Using connection parameters : 'contoso.com\rick:
Nspi/TCP-IP, [sea-exch2010-a.contoso.com/Negotiate]'
VERBOSE: [17:53:49.224 GMT] Test-OutlookConnectivity : Address Book Operation = 'Bind'
VERBOSE: [17:53:49.364 GMT] Test-OutlookConnectivity : Address Book Operation = 'GetHierarchyInfo'
VERBOSE: [17:53:49.442 GMT] Test-OutlookConnectivity : Address Book Operation = 'QueryHomeMDB', Input =
'primarySmtpAddress', Input Value = 'rick@contoso.com'
VERBOSE: [17:53:49.583 GMT] Test-OutlookConnectivity : /o=Contoso/ou=Exchange Administrative Group
(FYDIBOHF23SPDLT)/cn=Configuration/cn=Servers/cn=mail.contoso.com/cn=Microsoft Private MDB
VERBOSE: [17:53:49.583 GMT] Test-OutlookConnectivity : /O=Contoso/OU=NY/cn=Recipients/cn=rick
VERBOSE: [17:53:49.583 GMT] Test-OutlookConnectivity : Address Book Operation = 'GetNetworkAddresses', Input =
'serverLegacyDN', Input Value = '/o=Contoso/ou=Exchange Administrative Group
(FYDIBOHF23SPDLT)/cn=Configuration/cn=Servers/cn=mail.contoso.com'
VERBOSE: [17:53:49.614 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:49.614 GMT] Test-OutlookConnectivity : Using connection parameters : 'contoso.com\rick: Mailbox/TCP-IP, [mail.contoso.com/Negotiate]'
VERBOSE: [17:53:49.630 GMT] Test-OutlookConnectivity : Mailbox Operation: 'EcDoConnectEx', Target mailbox: '/O=Contoso/OU=NY/cn=Recipients/cn=rick'
VERBOSE: [17:53:49.630 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:50.317 GMT] Test-OutlookConnectivity : EcDoConnectEx Result: '0'
VERBOSE: [17:53:50.317 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:50.333 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:50.849 GMT] Test-OutlookConnectivity : EcDoRpcExt2 Response - Result: '0'
VERBOSE: [17:53:50.849 GMT] Test-OutlookConnectivity : EcDoRpcExt2 Response - Error code: '0'
VERBOSE: [17:53:50.849 GMT] Test-OutlookConnectivity : RPC Endpoint = 'mail.contoso.com'
VERBOSE: [17:53:50.864 GMT] Test-OutlookConnectivity : Admin Audit Log: Entered Handler:OnComplete.
VERBOSE: [17:53:50.880 GMT] Test-OutlookConnectivity : Ending processing &
[PS] C:\Windows\system32>Test-OutlookConnectivity -Protocol:TCP -Identity contoso.com\rick -MailboxCredential:(g
et-credential contoso.com\rick) -verbose | Fl C:\Test1.txt
VERBOSE: [17:50:45.403 GMT] Test-OutlookConnectivity : Active Directory session settings for 'Test-OutlookConnectivity'
'DC1.contoso.com', Preferred Global Catalog: 'DC.contoso.com', Preferred Domain Controllers: '{DC.contoso.com }'
VERBOSE: [17:50:45.403 GMT] Test-OutlookConnectivity : Runspace context: Executing user: contoso.com/User
VERBOSE: [17:50:45.403 GMT] Test-OutlookConnectivity : Beginning processing &
VERBOSE: [17:50:45.403 GMT] Test-OutlookConnectivity : Instantiating handler with index 0 for cmdlet extension agent
VERBOSE: [17:50:45.403 GMT] Test-OutlookConnectivity : Current ScopeSet is: { Recipient Read Scope: {{, }}, Recipient
VERBOSE: [17:50:45.419 GMT] Test-OutlookConnectivity : Resolved current organization: .
VERBOSE: [17:50:45.434 GMT] Test-OutlookConnectivity : Mailbox = 'contoso.com\rick', Owner = '/O=Contoso /OU=NY/cn=Recipients/cn=rick'
VERBOSE: [17:50:45.434 GMT] Test-OutlookConnectivity : SMTP address for Autodiscover request ='rick@contoso.com'
VERBOSE: [17:50:45.466 GMT] Test-OutlookConnectivity : When contacting
https://CAS1.contoso.com/autodiscover/autodiscover.xml received the error The underlying connection was
closed: Could not establish trust relationship for the SSL/TLS secure channel.
https://CAS1.contoso.com/autodiscover/autodiscover.xml received the error The remote certificate is invalid according to the validation procedure.
VERBOSE: [17:50:45.466 GMT] Test-OutlookConnectivity : <?xml version=" 1.0" ?>
<Autodiscover xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd=" http://www.w3.org/2001/XMLSchema"
xsi:nil=" true" xmlns=" http://schemas.microsoft.com/exchange/autodiscover/responseschema/2006" />
VERBOSE: [17:46:07.756 GMT] Test-OutlookConnectivity : Admin Audit Log: Entered Handler:OnComplete.
+ FullyQualifiedErrorId : 73CEA5CD,Microsoft.Exchange.Monitoring.TestOutlookConnectivityTask
VERBOSE: [17:46:07.772 GMT] Test-OutlookConnectivity : Ending processing
Raul
Rrr2011
DC.contoso.com }'
EEInfo: Flags: 0
James-Luo
Error: &ldquo;Could not establish trust relationship for the SSL/TLS secure channel&rdquo;
Default Website is set to listen to 443 SSL but no certificate is assigned to the listener. Since it"s a lab, please assign a certificate by using windows CA
Is there anything in the &ldquo;RPC Client Access&rdquo; folder?
James Luo
Rrr2011
Hi James,
I have installed certificate thru IIS 7 and change the bindings. Still same error. CASarray FQDN is not working. I am not sure where is RPC client access folder. Where should I chekc that?
I am planning to setup everything in production now. We have 3 servers 2 at main site and 1 DR site. I have installed hub/cas/mailbox in all servers. We are using HLB at main site to LB CAS trafffic. DR site dont have direct internet. We want DR site users to connect with DR site CASarray2. Can you give me more idea about how does this work? Will users at DR site will connect to CASarray 2 to CASarray 1 , because DR site doesnt have direct internet connetion and its connected to main site.
and what things I should keep in mind before creating CAS array and load balancing with HLB?
ALso I heard that you need to change some registry setting MXexchhangeRPC and add that port number that you want to load balance. Is that true or not mandatory?
I will greatly appreciate your time. Thanks.
Rrr2011
Test-Outlook connectivity fails with below error
Certificates are installed correctly. Still not able to have CASarray working.
Any direcitons will be appreciated. Thanks.
Rrr2011
Issue got resolved with readding CAS role.
Thanks for sharing your thoughts.
