Autodiscover not issuing CAS array to Outlook Clients
jimbravo
Autodiscover, following a migration from Exchange 2003, issues CASServer1 for some users and other users CASArray. I'd like to set Autodiscover to hand out CASArray for each user. The OAB, RPC, OWA, EWS all are set with the mail.domain.com are working as they should. However, when Autodiscover is handing out Server1 to Outlook clients when they logon, I lose the redundancy which I hoped to get by deploying two cas servers. Does anyone know how to set the Autodiscover to hand out CASArray as opposed to Server1 to Outlook clients?
Busbar [MVP]
did you configure the RPCCLIENTACCESSARRAY properties on the mailbox database?!Regards, Mahmoud Magdy Watch Arabic Level 300 Videos about Exchange 2010 here: http://vimeo.com/user3271816 Read pretty advanced Exchange stuff I post here: http://www.enowconsulting.com/ese/blog.asp, follow my blog: http://autodiscover.wordpress.com , corp blog: http://ingazat.wordpress.com, Follow me on twitter http://www.twitter.com/_busbar and if you Liked my post please mark it as helpful and accept it as an answer
Bryan Sprowls
if the CAS array was created after the mailbox databases you will need to set the RPC Client Access server on the database:
Set-MailboxDatabase <name of DB> -RpcClientAccessServer "casarrayfqdn"
B AutoDiscover Forensics Exchange Server Administration 0
EXChange2013 Exchange 2013 AutoDiscover Tweaks? Exchange Server Administration 0
M Outlook 2007 AutoDiscover Using Outlook 0
A Exchange Autodiscover SSL issue Exchange Server Administration 7
M Initial Outlook Configuration with AutoDiscover populates wrong email address Using Outlook 5
N Outlook 2007 Clients Pointed to Wrong Domain Name for Autodiscover Using Outlook 2
K testing autodiscover and exchange coexistence Exchange Server Administration 2
C The Autodiscover service couldn't be located. Exchange Server Administration 8
C Exchange server 2010 error "The Autodiscover service couldn't be located." Exchange Server Administration 1
J Autodiscover accounts on exchange 2003 with Outloook 2010 not working Using Outlook 4
Z Autodiscover Points to defunct Exchange 2010 Server Exchange Server Administration 5
M Autodiscover not configuring Outlook Anywhere Using Outlook 10
B Autodiscover error 0x800c8203 and encrypted connection is not available Exchange Server Administration 3
P Autodiscover URLs Exchange Server Administration 15
C Autodiscover Exchange Server Administration 6
I Exchange 2010 Profile AutoDiscover not working for some users Exchange Server Administration 1
S Exhcange 2010 autodiscover virtual directory Exchange Server Administration 4
D External Autodiscover Exchange Server Administration 3
S Exchange 2010 Autodiscover Problems, cannot connect Outlook clients using Autodiscover / Outlook Any Exchange Server Administration 4
G Exchange 2010/Outlook 2007 Can't get autodiscover to work for some users, but others work fine Exchange Server Administration 3
S Autodiscover issue Exchange 2007 Using Outlook 4
P Autodiscover will not work Exchange Server Administration 13
K Exchange 2010 Autodiscover Exchange Server Administration 1
P Autodiscover fails (Exchange 2010) Exchange Server Administration 7
P Autodiscover issues on Exchange 2010 Exchange Server Administration 7
S Exchange 2010 Outlook 2010 Autodiscover fails Exchange Server Administration 22
C Getting Autodiscover to work with other web servers ... Using Outlook 4
C Autodiscover Service Configuration Exchange Server Administration 5
B move mailbox- autodiscover Exchange Server Administration 25
T Autodiscover authentication Exchange Server Administration 2
A autodiscover issue with OL2010 but no issue with OL2007 Exchange Server Administration 10
K Autodiscover and SRV records Using Outlook 10
S Autodiscover redirected Using Outlook 2
C Autodiscover Exchange Server Administration 5
S Autodiscover two AD sites two cas arrays Exchange Server Administration 4
O Autodiscover Exchange Server Administration 4
S Autodiscover FQDN certificate for secondary domain email? Exchange Server Administration 1
K Remove AlternativeMailbox - Autodiscover Exchange Server Administration 5
S Exchange 2010 autodiscover Exchange Server Administration 4
R Autodiscover virtual directory - recreation fails Exchange Server Administration 1
A share one record for autodiscover between exch 2007 and exch 2010 Exchange Server Administration 4
O SSL certificate needed for autodiscover.domain.com Exchange Server Administration 12
C Windows 7/Outlook 2010 vs Windows XP/Outlook 2007 - Autodiscover authentication looping Using Outlook 1
